Question about ZAGG Tablets & eReaders
Zagg profolio tyes wrong characters with shift key
Profolio
Light stays on charging, doesn't shut off..... Doesn't hold a charge
Hello, Pull the electric cord and let the battery run all the way down. Pull the battery out and try powering up and down on the switch without the battery in. If that works then you have a bad battery.
Oct 04, 2015 | ZAGG Apple Folio Case With Keyboard For...
Can not get keyboard to pair with ipad
Make sure the keyboard has been fully charged. Most BT keyboards do have provisions to get power from the iPad.
Jul 18, 2014 | ZAGGkeys Cover and Bluetooth Keyboard for...
Tablet onscreen keyboard keeps reversing capslock.
Hi Melissa
When does this happen? Hitting Return/Enter/or the
key will generally throw this up. It is also noticeable on spreadsheets which jump to the next specified cell and automatically create a leading upper case character in the cell just used. These are operating system or program settings.
Try noting when this happens and then re-create it to be sure. Log the sequence to see if there are any keys which are involved (also the length of time or even just tapping a key or spot on the tablet surface can have a totally different meaning)
Hope this helps....
May 19, 2014 | Tablets & eReaders
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Zagg keyboard Will not work after connected by Bluetooth in ipad2
I have a Zagg keyboard for my iPad mini. I found the same thing happened but then realized it only works in most apps, not all. For example it doesnt work when typing in a password in settings. Try you keyboard in an app like notes. Also make sure you haveheld down the power for long enough that the light is red for 5 seconds.
Sep 28, 2013 | Apple iPad 2 Wifi 16GB
Delete character
You have this backwarrds. The backspace key (<-) deletes from right to left. Try using the the Delete key
May 11, 2013 | Apple iPad 32 GB WiFi Tablet PC
Both of shift key on my keyboard are always turn on..how to make it fix..?and i can't to restore the system..
i have the same problem.
I run the windows screen keyboard and i discovered that when i press both r+t keys and u+y both shifts are switching on. i'm not able to switch it off even using mouse on screen keyboard.
as temporary workaround i press fn key then i press shift on screen keyboard, then both shifts switches off.
i didn't fount full solution.
Jul 08, 2009 | Toshiba Tablets & eReaders
Keys enter wrong characters
You have Num Lock on. Turn it off.Generally Function and End or one of those keys.
Feb 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Tablets & eReaders Logo
21 people viewed this question
Top ZAGG Tablets & eReaders Experts
Steve
Danny Kuhlmann
Sam Bedggood
Are you a ZAGG Tablet and eReader Expert? Answer questions, earn points and help others
