With what software I should use to repartition Hard Drive 9 partition magic or active @?
I have used Partition Magic and it worked well. Below is the link to the free edtion.
http://download.cnet.com/EaseUS-Partition-Master-Free-Edition/3000-2248_4-10863346.html
SOURCE: Windows is booting to recovery partition How do I stop it?
Check your CD-rom for any Installation CD in there, normarlly you go to bios to set which drive to boot from,. Ok when restart, press delete to go into bios. choose boot from HDD.
SOURCE: After loading from both recovery disks, installation stops
Shouldn't take two hours, but if it does? I would just start the installation and walk away and check back every half hour or so just to see if input from you is required to continue, but if not just walk away for a while again and the installation disk should do it's job.
SOURCE: Hard Drive Error during system recovery
You need to run a hard drive diagnostic disk in dos,(before windows starts) First check with HP, You can also use a program called HDD Regenerator 1.51. This will check the drive for bad sectors, and then you can try and repair them. This way you might
be able to see some of the data you want. If the sectors that where
repaired had the operating system on them, you should just get a new drive,(if not under warranty) then after you have a new OS installed on the new drive, you can plug in the old drive and see what you can recover.
You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
SOURCE: how do i recover a HP pavilion a1410y to a new
You might be able to use a drive cloning program such as HD Clone from Miray to clone everything to a new drive then do the recovery.
