Question about Energizer Weather Ready 4 LED Flashlight With Optional Size Batteries
Change batteries for weatherready flashlight
Can not make combination of batteries work
I changed the batteries positive to positive not working.
Put the batteries in positive (+) end first, continue putting the batteries in where the positive touches the negative (-) end of the previous battery.
Nov 18, 2016 | Energizer Camping, Backpacking & Hiking
Energizer WeatherReady lantern came with batteries; worked once. Can't unscrew the top to change batteries. Possible battery corrosion? Is there a workaround fix?
Mix water and baking soda together until baking soda is dissolved.
Take a small baking pan or a bowel with a flat bottom and place the lantern in a vertical position, bottom down and slowly pour in the baking soda solution so the solution is 1/4" above the battery lid so the solution can soak into the threads of the lid. Let sit overnight. Next morning, slowly lift the lantern out of the solution without tipping it keeping it vertical, and slowly unscrew the lid over the sink. Keep in mind there will be solution inside the lantern when you first open it, so be careful not to tip it until you dry out the inside.
Aug 31, 2016 | Energizer Camping, Backpacking & Hiking
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
Not sure which bit to unscrew when trying change battery in onyx50
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
Apr 06, 2016 | Gerber 22-80144 Onyx 50 Flashlight
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
Won't work after changing batteries
If the flashlight was working properly before you changed batteries, it's most likely that some tolerance is off by just a smidge so that you're not getting quite the right contact to close the circuit. You can make a thin wafer out of aluminum foil that's folded over and over onto itself and use that as a shim to increase pressure on the battery cartridge. That may be all you need.
If there is a switch on this light, as opposed to a simple screw on/screw off pressure connection, I would try checking continuity in the switch to make sure that is working correctly. Many manufacturers cut corners on the fit and construction of their flashlight swtiches, so a part can go out of alignment quickly and easily, causing failure of the switch until you can nudge those parts back in line.
Nov 25, 2012 | Leatherman Led Lenser L7 Flashlight
I had to change the battery 2 D and now it doesn't work. I have never had one work after I change the batterys what am I doing wrong?
Unless the bulb is burned out or you are putting the batteries in wrong there is not much that can go wrong with a flashlight.
Jan 22, 2010 | MagLite Mag Instrument Mag Lite 2 "D"...
Changed the batteries......now can't get it to work.
if you cant even put the batteries in, how am i going to teach you to code it? there is diagram in side case showing PLUS up or down, follow it. both go in same way, why would you put neg to neg. do yu do that with flashlight batteries. come on.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My master lock 1547 lock combination was changed and i cant open it
If you have the change key, you can insert into the lock and make a new combination. Only the Change Key witll allow you to change combination.
Artgirl
Jul 16, 2008 | Master Lock 5400d: Portable Select Access...
Energizer Weather Ready 4 LED Flashlight With Optional Size Batteries Logo
27 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
NicK Hale
Level 1 Expert
Tom Chichester
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
