Question about Tablets & eReaders
Tablet manual clickonica
When typing cn not delete letters, tablet tries to predict by pumping in loads of random letters & numbers
Going to other screens without touching icon and typing random letters when typing. How do I fix?
check for a sensativitty adjustment, if not you may need a new screen
Jan 19, 2016 | Tablets & eReaders
Tip
Model Z54F, Check No 4272
Please advise On a spanish keyboard there are numbers on letters JKLOPIUñM, when I type a sentence I have to press fn before i can type letters, how do I get it back to normal
on Jul 26, 2008 | ASUS R1E-B1 Tablet PC
Every time i try to type a word to down load a app on the google store it clicks to the home screen.
when typing in the name off app on the keyboard you type on Press the ENTER button and not the home button on tablet .
Dec 28, 2015 | Iview 7" Android 4.0 Tablet PC Model:...
My nook will'not change to numbers.stays on letters.any suggestions?
I assume you mean the Nook keyboard doesn't allow switching between numbers and letters. The built in Nook keyboard isn't the smartest or only keyboard app out there. Now that it's totally free strongly recommend you go into the Google Play Store and install SwiftKey. One hour using it and you'll wonder why you ever put up with Barnes and Nobles chunky idea of a keyboard. Even Google itself has their own keyboard app. You can have multiple keyboard apps installed at the same time. Just use the Switch Keyboard option to toggle between then.
As far as SwiftKey is concerned one of the main features that first sold me on it is it can be resized. I always hated the Nook keyboard just took up so much of your available screen space leaving so little for the input area. Did you know SwiftKey can be setup to show a numbers row at the top just like a regular PC keyboard? Also it can learn your typing patterns over time and predict the most likely word you will use next. Just click the word in the predictions bar.
Jan 22, 2015 | Barnes & Noble Nook Tablet
How to turn on predictive text on my asus tablet
Hi
I found the manual for your tablet here:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF300T/TF300T_MANUAL_en_20120423.pdf
It is in pdf format and can therefore be saved to computer for future reference. Searching through the manual there was no reference to "predictive" in the whole manual and searching "text" didn't give any indication that this facility is available on the machine as standard.
Nov 23, 2014 | ASUS Transformer Tf300t Tablet Keyboard...
Some key on the keyboard are typing numbers instead of letters what should i do please?
You might have accidentally activated the "Numlock" key on your keyboard. Just press the Numlock and it should type in letters instead of numbers.
If press just the Numlock key will not work, try the combination which is CTRL and Numlock simultaneously.
Hope this helps.
Jun 17, 2011 | Tablets & eReaders
My Toshiba Satellite Pro A300-GR laptop wont type the letters o l k i and numbers eight and nine as well as comma - stop - down arrow not working - right arrow not working and delete key not working - also...
You have Number Lock set on your PC - Have a look for a key top right hand side, it will have something like NumLck written on the KEY - you may need to use that Key in combination with the FN key - bottom left of keyboard - there should be a light somewhere on the keyboard which goes on/off as you toggle the NumLck key. You should see different coloured numbers on the key s*()UIOPJKLM These are the numbers and symbols that will be displayed when the NumLock is used
Apr 15, 2010 | Toshiba Portege M205-S810 Tablet PC
My keyboard wont type anything, the mouse works, but when i try to type it wont do anything, the buttons do work because when i open word to try to type if i click f the file drops down and when i click v...
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
Oct 07, 2009 | Toshiba Tecra M4-S435 Tablet PC
Numbers typed with letters
What Operating system have you got?
Try resetting your regional settings in Control Panel.
Have you dropped it accidently?
Aug 15, 2008 | Fujitsu LIFEBOOK P1510D Tablet PC
Tablets & eReaders Logo
130 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
