HP Photosmart 3310 Printer
Problem for HP Photosmart 3310 Printer
SCAN,COPY,FAX PROBLEM
By jimsub on Oct 26, 2007
UNABLE TO SCAN,COPY OR SEND A FAX IS DISPLAYED ON PRINTER
UPON TURN ON.
Comments:
Nov 04, 2007
- printer is able to print stuff from computer via wireless
yet anything to do with scanner bed is n.g.
unit fails its' self check upon turn on with message
of "unable to scan,copy or fax".i guess i need to bring it somewhere
It' a year and a month old.just out of warranty.Damn.
thanks for trying though.
Jim Sub
Same Problem
May 19, 2009
-   Same problem with grinding noise and scanner failure. I can copy and print but not fax or scan. Anyone have ideas how to fix? -   eking537
Feb 06, 2009
-   I have the same problem with scanning. I get the loud grinding noise then it fails. Any one know how to fix it? -   Guest
May 13, 2008
-   I have the same problem, but turning off the printer and taking out the cartridges then turning it back on and putting cartridges back in DOES NOT WORK....is this a manufacturing fault!!
Peter Chuter Surrey-   Guest
May 07, 2008
-   Can not scan anything.  I have no idea what to do about it.  It just prints black pages when trying to make copies. -   jwag
Apr 26, 2008
-   I have the same issue. Scanner passes over the document to be faxed, then when it attempts to return to its home position, it makes a grinding sound and gives the "unable to scan, copy or send a fax" error.-   taylor924
Best Solution
posted on May 16, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
unable to scan,copy or send a fax.I can copy from desktop help R.FARDA
Solution #2
posted on Nov 01, 2007
Somewhat Helpful)
tom19511
Rank: Guru  HP Expert
Rating: 85%, 2171 votes
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Comments:
Nov 06, 2007
- Did this work?
Please post an answer so we can help you further.
If it worked please rate this post as solved.
Thanks,
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2009
Somewhat Helpful)
covelloj
Rank: Apprentice
Rating: 75%, 1 votes
Hi, believe it or not, this worked..,
unplug unit for 30 sec.
press and hold # key plus 3 key (keep holding)
plug in unit again
keep holding # and 3 buttons until screen says reset has occurred
release buttons, try copying or scanning
if you're lucky, you'll now have a functioning unit
Was this helpful?
Yes
No
Solution #4
posted on Feb 01, 2009
Not Rated)
walfredo
Rank: Apprentice
Rating: 0%, 0 votes
Amigo, só para ajudar a divulgar aos usuários de Bulk. Se o código de erro 0xc18xxxxx ou 0xc19xxxxx do sistema de tinta da impressora HP Photosmart C6180 for exibido no painel dianteiro, faça o resete da seguinte forma:
1- aperte a tecla com sinal # (jogo da velha) e o número 9. Segure as 2 (# + 9) apertadas ao mesmo tempo.
2- desplugue a impressora da energia,
3- ligue (com as teclas ainda apertadas) e espere uns 15 segundos até a impressora desligar.
4- Aí é tudo normal, liga novamente ela pede as configurações iniciais, configuração da linguagem, faz a limpeza e OK!
A tinta preta original da impressora C6180 é pigmentada e as demais corantes. Contudo para o bulk-ink é melhor utilizar só tintas corantes que possuem melhor fluidez, evitando entupimentos e problemas. RESOLVI O PROBLEMA DO MEU BULK-INK SUBSTITUINDO A TINTA PIGMENTADA - QUE VEIO COM O BULK - POR TINTA TIPO CORANTE.
Was this helpful?
Yes
No
Solution #5
posted on Sep 16, 2008
Not Rated)
chrisbowater
Rank: Apprentice
Rating: 0%, 0 votes
On trying to fax my photosmart C7180 to and international number it scans my 3 sheets and then grinds and also dials the number then when the arrow n he screen shows page 1 is faxing it just stops and prints out error 350
Thanks
Chris
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart 3310 Printer
Questions and Unsolved Problems for HP Photosmart 3310 Printer
Do you recommend HP Photosmart 3310 Printer?
Answer
Answer
phone is no signal 3310 nokia
Answer
what does oxc18ao26 on hp mean my printer wont print how do i reser
Answer
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system... (More)
Answer
cannot print a photo from the computer...photo tray is filled but it keeps asking for paper in the... (More)
Answer
I had my old dell crash and had to buy a toshiba a505-s6965 this weekend and I can't get the... (More)
7 Other Users Have The Same Problem - Continued
Comment by Fred M, posted on Jan 07, 2008
Yes I have the same issue with my HP 3310. Is it a lamp fault requiring replacement or could it be a software issue? Any suggestions re fix?
Cheers,
Fred M
Comment by kismie, posted on Nov 29, 2007
My printer says Scanner failure, unable to scan, copy, or fax. I turned it off, and unplugged it, pulled out all the ink cartiages, but when i turned it back on and installed the cartiages back, it still had the same error. Anything else i can try?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart 3310 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
