Question about Asko W6461 Front Load Washer
Asko W6461 F6 fejlkode - Asko W6461 Front Load Washer
3 Suggested Answers
SOURCE: Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Posted on Sep 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: ASKO W6461. Washing machine won't unlock and my
Welcome to FixYa.
Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? In the event it is clogged or the filter obstructed, will prevent the door lock from releasing.
This is by design, but it's easy to confirm or dismiss.
Check as follows...
Let me know if any of this isn't clear and I'll attempt to help you move forward. Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now pull the manual door lock release located in the same area.
i.e.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on Nov 10, 2010
Testimonial: "Feedback was excellent. Instructions easy to follow and we have just started our first load. And we probably have over $2 in change from our pump!"
We have an ASKO W6451 flashing F6. appears to jump from 1 minute to go to 20 minutes to go then flashes F6. would it be something electical?
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
Dec 27, 2014 | Asko Washing Machines
F6 - error message
My W6461 keeps repeating the cycle, doesn't shut off. Anyone experience this?
Mar 12, 2014 | Asko W6461 Front Load Washer
What does a F6 error message indicate?
"F6" Motor fault · Check wiring to motor · Replace motor if necessary
Oct 12, 2011 | Asko W6461 Front Load Washer
Who do you set timer on asko 6461 washer?
the timer you are trying to set is for a delay start. so if you set the timer for 1 hr, the machine will start 1 hr later.
Feb 05, 2011 | Asko W6461 Front Load Washer
With my Asko W6461, Right as the spin cycle starts, it sounds like something hard is banging against the drum (outside it) but inside the washer. Often, the spin cycle then does not complete. When I turn...
buy a new machine,the spider gear is broken and it's around 500 bucks for the part,you can buy a new washer for that,you used to much detergent,it eats at the metal on the spider gear and it falls apart,i've found parts of it inside the pump before.
Oct 19, 2010 | Asko W6461 Front Load Washer
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Jun 15, 2010 | Asko W6461 Front Load Washer
Sep 18, 2009 | Asko W6461 Front Load Washer
Asko 12505
It's probably the heater, or the thermostat. You must have a serviceman to fix that:)
Feb 03, 2008 | Asko W6461 Front Load Washer
Asko front load washing machine
ring the asko service number on the inside of your door,1300 002756 ask for spare parts
Dec 15, 2007 | Asko W6461 Front Load Washer
Asko W6461 Front Load Washer Logo
52 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
