Question about Gaggia Platinum Swing 2-Cup Coffee Maker
Error code 1 on gaggia platinum swing
Where can I get a listing of error codes for a Gaggia Platinum Swing?
4 Suggested Answers
SOURCE: Gaggia Platinum vision (not in
I fixed it!!!
Take the brew unit out and remove the grey inlet peice (2 screws) then take out the peice with the perforated disc in it out and remove the disc. Clean the disc so you can see through all the holes and re-assemble.
This sorted my machine out and it now behaves correctly again.
Posted on Jan 03, 2009
SOURCE: Looking for an english manual for Gaggia Platinum
Hi
I have the original manual (a bit marked) but a better solution is to download the manual for the Swing Model from http://nettopdf.info/download.html?dl=aHR0cDovL3d3dy5jaGV6YmV0dGF5LmNvbS9pbWFnZXMvZ2FnZ2lhL2dhZ2dpYSUyMHBsYXRpbnVtJTIwc3dpbmcucGRm&t=pdf&name=Gaggia%20Platinum%20Swing%20Operation
The only difference is the manual, instead of electrical mechanism that moves the cup(s) up and down.
Cheers
Liz
Posted on Oct 22, 2010
SOURCE: My gaggia platinum is showing an out of service
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Posted on Nov 21, 2010
Water tank is full on my gaggia plaitium swing up but it is asking me to fill water tank
Then the float or sensor is not ingaging to show that there is water to that level so i would try to dump some water down a few times and force the float back up or try to reach it with your hand and move it very easily up and down then try to fill it and i bet it works fine. Thanks
Sep 03, 2012 | Gaggia 102498 Platinum Swing Automatic...
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
Nov 11, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Looking for an english manual for Gaggia Platinum Swing Up coffee machine.
Hi
Cheers
Liz
Oct 07, 2010 | Gaggia 90901 Platinum Swing Up Automatic...
I have a gaggia platiniun bean to cup. i am using ground coffee at the moment but it keeps coming up brewing failed Why?
The grind might be too fine, and so the machine extract the coffee, try making the grind a little coarser.
May 30, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
I cannot get the brew group out to clean in my Gaggia Platinum swing 2-cup. It seems to be jammed. Any ideas? I've unplugged, then turned it back on and it doesn not unstick so that the gears line up...
Check the position of the gear if the small arrow is not matching with the N this mean that you have a mechanical gear problem and need to desasembe the machine in order to find the broken part. If the arrow mutch with N the the problem is due to coffee that dry out and the group is only stuck in, by a little force and a slight movements left and right you can easily unstuck and you can clean it with running hot water under tap. The problem it can also by a brocken lock lever so when you press the level by your hand this is broken and can not unlock the group so you can remove it out. You can try to use a long screwdriver to unlock it so it can then remove it.
Good Luck
Please remeber to vote for this answer
Feb 22, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia Platinum Swing Brew group will not relocate into position. I have checked all the alignments of the movable parts, but just will not relocate into position. Seems to be a problem with the alignment...
Sometimes if you, turn the machine on without the unit in place it will reset itself, and if on the brew unit the arrow is pointing to the N, then you should be fine, however if the arrow is doing its thing and the gears do not line up then you might have to take it in to get it reprogrammed.
Feb 07, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
Red light on my machine
Hello Jennifer. It's nice to see a name. My name is Ned. I'm typing in Grsggia in the search bar to see what pops up. You may want to also.
Sep 27, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia Platinum Swing 2-Cup Coffee Maker Logo
70 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
