Maintenance code for dcp-1511 - Office Equipment & Supplies
How to reset drum brother dcp-1511
You can find the reset procedure on Brothers support site here http://support.brother.com/g/b/faqend.aspx?c=as_ot&lang=en&prod=mfc1810_us_eu_as&faqid=faq00002837_019
If you have any problems beyond this then simply reply to this post and I will be happy to help.
Feb 16, 2015 | Brother Office Equipment & Supplies
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Where do I get an ink absorber box for my brother dcp-135c printer
There is no reason to clean or replace. Just reset counter with this procedure.
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Jan 28, 2011 | Brother DCP-135C Flatbed Digital MFC...
I cannot print from printer brother DCP-135C with an error message - Clean Unable 46, please assist
Clean unable 46 error on dcp 135c brother printer
May 19, 2010 | Brother DCP-350C InkJet Printer
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
To get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
Dec 18, 2008 | Brother DCP-8040 Copier
Brother DCP-110C Error 41
sorry. ph is defective and needs replacement.
Mar 29, 2008 | Brother DCP-110C All-In-One InkJet Printer
107 people viewed this question
jasbo
jasbo
