Question about Seiki Televison & Video
My volume stopped working on my seiki tv
My volume went out on my tv..It seemed like I was not able to hear it for a few weeks and kept turning it up and up and now no volume when I turned it on today. It was working last night
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
Posted on Nov 04, 2008
  • 5 Answers
SOURCE: Protron pltv3250 32 in. lcd, no power, no lights
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
  • 187 Answers
SOURCE: Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
While watching my 32" less than 2 year old seiki tv the picture went completely black while the volume still continued. what is wrong?
No backlight. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
May 23, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Sharp aquos will not turn on. power opc light flashing
I got a Sharp Aquos Quattron LC-60LE847U, a 60inch LED TV, I only brought it for a year and 4 months, factory only a have one year warranty. Last week when my kid try to turn on the TV, the TV power light keep repeat blinking in 2 slow and 5 fast sequence, don't know what did it mean. When I press the power button, the light will stay on for few seconds and it kept blinking after, the TV cannot turn on at all.
My kid have called the Sharp help line in US, number found in user manual, but the Canada help line are different number, it is 1-877-278-6709, they told my kid to unplug the TV, hold down the Input and the Volume down key, then plug the power back on, the TV can turn into service mode, it have a K icon on the screen, but every time I selected the menu, it went away very quick. Then the customer assistant told my kid to call service.
When I did a lot of research, every solution seems to point to the power supply, so I bought a power supply from ebay, replaced it, it does the same thing, no different at all, then I turn the TV back on in service mode, to try to do a reset from the menu, upgrade the firmware, re-seat all ribbon cables of the main board and the middle logic board (Not sure what is that board call, it is in the middle of the TV), neither way can make any different, the TV light still blinking in same sequence.
So I kept doing the research, I find out another way to reset the TV back to factory setting just by holding down the Volume up and Channel down, then plug in the TV, kept hold it down those 2 buttons until the TV came back on. TV will reset for just by doing this. Happy news, problem seems to get fixed, but not 100 %. The TV seems no problem to turn off and on after reset, but if I unplugged it, the blinking problem will come back, but if I reset it one more time, it will works again until I unplug it again. It is better than completely dead.
Then I unplug the TV, removed all ribbon cables (6 ribbon connectors), use sand paper to clean all the ribbon cable contacts, don't rub it too hard in case the cable contacts get destroy, then re-seat all the ribbon cables. After I did that, everything back to normal and my TV got fixed completely.
This seems to be my way to fix it, not sure everyone can use the same method to fix their blinking power light problem, but I hope this tips can help some people to save big buck to the Sharp service. This TV is over $2000 dollars and I brought few pair of the expensive 3D glasses, I do hope it can last longer, didn't expect it have problem already, it just less than a year and half old and even I bought the power supply to tried to fix it but I ended up didn't needed to spend any money and solved the problem.
Hope this helps.
Aug 22, 2012 | Sharp AQUOS LC60LE847U 60 inch 1080p...
We were watching tv, and it was a storm. My lights went out and the tv turn off, when we turned it on again it wouldn't show picture but you could hear sound. We waited a couple of months to actually...
what caused the inital problem was a surge of energy caused by the storm. the exact problem, i don't know but it may just be that some of the power cord(including the power cord wires on the of the TV) wires have blown
Mar 05, 2011 | RCA M50WH185 Television
95 corolla has been stalling at random for the last couple of weeks. It only did it a few times then it would drive perfectly. Today I was driving in hilly terrain and it started stalling alot more than...
Check the fuel pump for pressure and volume. I had an Accord with the same symptoms. It would pump the proper volume when measured at the ground, but would not pump the fuel up high enough on the car, so it would fail on hilly sections.
Jul 21, 2017 | 1995 Toyota Corolla
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
