Question about Epic A35T Treadmill
Chip replacement A35T
I was sent a chip to replace for a A35T, where is this chip located
Locating Sony Vaio Touchpad replacement part(s)
Try using this company sales@laptopbits.co.uk
this is who we use for our supplier they have even sent us just a replacement DC jack at reasonable prices
Jan 17, 2014 | Computers & Internet
I just got an Epic A35T and the console will not tilt. Could it just be the wires are pinched?
could be 2) test the mechanics parts for try to LUBE 3) see your instruction manual, and see how to assembly if you do not have it download from
www.fitness.manualsonline.com
God bless you
Nov 22, 2012 | Epic A35T Treadmill
Toshiba tp50g90 projection tv, red flashing light won't turn on
FYI: WHOEVER told you 110 chips can be replaced with 120 chips is wrong.
Easy way at this point to way at this point to see if chips are the problem is to UNSOLDER AND REMOVE BOTH CHIPS. Make sure not shorted connections and power set up---set will function without the chips but look terrible.
Try Suburban Electronics for the correct chips----only safe replacement for them is the 150 chip----stk-392-110 and stk-392-120 are not interchangeable.
The blinking light indicates a short.
LET ME KNOW IF YOU HAVE QUESTIONS AS I HAVE FIXED hundreds OF THESE SETS.
Jan 16, 2012 | JVC Televison & Video
Can you sent me a picture of were to find the bios chip on the compaq presario f700 main board please. i can't change it if i don't know exactly, were to find it, in the main board thanks
The bios chip is not replaceable. If nothing is wrong with bios, live and let be. If bios is corrupt, a new motherboard is needed.
Mar 25, 2011 | Computers & Internet
I was given an L500. It powers but fails to POST, this happened after a recommended BIOS update. Any kind of debug ports or something to sort this out?
After a BIOS update, if it fails to post, the BIOS update got corrupted. This happens (rarely) and when it does, the only thing that can be done is to remove the BIOS chip and have it burned at a local repair shop (or sent into Toshiba for a replacement). Without the BIOS functioning properly, the computer can do nothing at all. If your BIOS is not on a removable chip, then the computer will have to be sent to Toshiba to have the BIOS replaced.
May 12, 2010 | Toshiba Satellite L500 Series Notebook
Where is thebios chip located on the motherdoard
the bios chip on almost all laptops are intergrated you can not replace them it is usally located between the processor and micro processor most repair shops can not replace them they soldered to the board if you done a bad flash go to www.badflash.com they may be able to help you
Oct 30, 2009 | Dell Latitude D620 Notebook
How do I locate the jumper so I can reset it?
The jumper is close by the CMOS battery.
Thanks
kindly rate
Kevin
Jul 07, 2009 | ASUS Eee PC 1000H Laptop
Phillips 51pw93 blue convergence chip bad.
Way to risky to replace one , besides
they are cheap 10.00 -20.00 etch
the load ballance is also offset from
0ne chip to another. They need to
be replaced as a set
Jun 30, 2009 | Televison & Video
No electric's, main fuse has blown, need to know location of same to replace. If possible, can diagram be sent?
under hood. you have to raise up the box and flip open side covers to unbolt 120 a41948728mp fuse.
May 28, 2009 | 1991 Lexus LS 400
Require value of D5
TomTom One uses a Linear Technologies chip LTC3455 as a USB/charger power controller. See http://cds.linear.com/docs/Datasheet/3455fc.pdf. This chip is susceptible to high transient voltages that result from resonances created by parasitic inductances and capacitances of the USB/in-car charger cable . Good designs using this chip suggest that a 1 ohm resistance be put in the path of the cable to reduce the Q of the resonance and hence transient voltages. A 6V Zener diode D5 also serves to protect the chip from these transients.
If the Zener diode is blown it is most likely the the LTC3455 chip is gone as well. You can replace the chip which costs £5.00 (located in the shielded portion of the PCB). The recommended Zener Diodes for this chip are either the EDZ5.6B or EDZ6.2B manufactured by ROHM (http://www.rohm.com/products/databook/di/pdf/edz5.6b.pdf or http://www.rohm.com/products/databook/di/pdf/edz6.2b.pdf). These can be used to replace D5. The STMicroeletronics SM2T6V8A can also be used to replace D5 (http://www.st.com/stonline/products/literature/ds/8694/sm2t.pdf). All the Zeners cost a modest £0.22. I hope this is helpful.
Emmanuel Zyambo
Jun 15, 2008 | Tomtom One XL GPS Receiver
Epic A35T Treadmill Logo
41 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
