Question about Pelonis HO0218 Oil Filled Electric Radiator Heater
The plug is very hot and is turning brown - Pelonis HO0218 Oil Filled Electric Radiator Heater
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
Which pins do i check for voltage on the plug for the rear wiper motor
On and off is black with white. Intermittent is brown/orange and brown /Lt green then pink/black hot all the time
Dec 12, 2011 | 1995 Jeep Grand Cherokee
Is brown wire neutral or hot is blue wire neutral or hot
Brown will be Live and Blue will be Neutral.
If you are looking at an opened plug in your hand, bLue will go to the left and bRown will go the right (see the capitals> thats how I remember it)
Jan 07, 2011 | Garden
Wiring 4 way flat trailer plug. brown wire running
you got brown for running parking light
green for right turn/stop
yellow for left turn/stop
white for ground
reverse lights are only wired on a 6 or 7 plug connector
make sure you on the dark green for right turn stop not the light green
the light green is for reverse
Jun 24, 2010 | 1999 Chevrolet Tahoe
Checked my spark plug today and found the tip to have browned of is this a problem with the mixture and how do I fix it?
I never heard of a brown plug. It should be black, blue, crud, or oil. The mix will turn the plug blue from being too rich, burning hot, and of course the black from soot or carbon, from being lean, Then the oil you don't want to see, but changing plugs is a must. I get great performance from Autolite plugs in my bike. 10 times better than champions. Clean the air filter while you are at it. Hope this helps.
May 25, 2010 | 2007 Yamaha Ybr 125
I am getting lots of brown flakes in valves
The brown flakes are most likely rust from either the tank or associated metal piping. They could also be from the anode used in hot water tanks to combat electrolysis. Does the water have a Sulphur" or "rotten egg" smell to it? Are you on a well? There shouldn't be so much, as to plug up the valves. Turn off your heat source to the hot water tank. At the bottom of the tank is a faucet. Hook a garden hose to it, run it out side where the hose lays lower than the faucet if possible and flush the tank untill you have clear water again. You may want to do this a couple of times to be sure you get rid of any sediment in the tank. When you are done flushing, make sure you have the air out of the tank by opening a hot water faucet until it runs clear with no "spurts" of air. Shut the faucet off and turn the gas back on, light the pilot light and see if the problem persists. Also have your water tested. Sears does this for free -just take a sample in and they will tell you what the hardness is.
Jan 15, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 2007 450F Yamaha won't start when it gets hot? Valves are in spec, went thru the carb, all clean??? Put a new hot start on too..still no workie?
hi there matey,, if she starts perfect wen shez cold ,,and u ride her up the road till shez hot,, does it start misfiring while u are riding it,then a quick check will be needed, if it does misfire then soon as she misfires while riding,,kill the engine and wip out the spark plugs and check wot the colour of the plugs are,, they should be a biscuit brown colour ,,either 1 and 4 plugs or 2 and 3 plugs will be the same ,, if say 1 and 4 are not a brown colour then u need to change that coil to 1 and 4,, at the end of the day mate ,, if she doesnt start wen hot ,,its usually a coil that is the prob,, any more help u need come back,, cheers
Mar 24, 2009 | 2004 Yamaha FZ6
How to wire up g.m. radio cd stereo?
If plugs do not match, here are the color codes:
BLACK PLUG
Orange-12v constant
Yellow: 12V acc (be careful. There are 2 yellows.The other is a speaker wire. Use the wire that turns on with the key.)
Gray:Illumination (be careful. 2 grays. the other is a speaker wire. Use the gray wire tht turns on with the lights)
Black: Ground
Brown: Digital Illumination (BCareful. There are2. One is a speaker wire. Use the one that lights up with dimmer switch)
WHITE PLUG
Tan: LF+
Gray: LF-
Lt.Green: RF+
Dk. Green: RF-
BLUE PLUG
Brown LR+
Yellow: LR-
Dk Blue: RR+
Lt. Blue: RR-
Laterz,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Car Audio & Video
Pelonis HO0218 Oil Filled Electric Radiator Heater Logo
51 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
