AMW LCD Monitor Display Model A913B
AMW LCD monitor model A913B not working. First the display disappeared, but the power button LED was lit. Now even that has ceased to work. Can the case be opened without special tools? I see mating surface around edge with two slots for prying back off? Are the front and back glued together, or do they have plastic tab connectors? If I can disassemble, is there a good prospect for simple repair or part replacement? Thanks for any help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
Try separating the wiring. Touching wires can cause cross-talk of signals. Separating wires stopped my "shadows" on my screen.
Posted on Jun 22, 2014
kevin000
  • 1847 Answers
SOURCE: screen width unadjustable
chk the resolution is as mentioned by the makers in the user mannul.
Posted on Jun 17, 2008
SOURCE: IC Power 19'' LCD-Will not Power Up- No Lites.
This is a follow up to my last submission about my discovery of bad caps on the FPD1960 LCD flat screen Gateway 19" computer monitor. To recap: After two and a half years of excellent graphics quality, my monitor suddenly went blackout. After pushing the power-on button, the screen would come on for 1-second, then go black. Repeat, again and again, same result; comes on for 1 second then blackout. THE REPAIR: After carefully but forcefully prying open the case, I unscrewed and unplugged then removed the screen and set it aside, then unscrewed and removed the power supply board. Sure as shootin, bulging (and slightly leaking) capacitors were immdiately apparant on this board. That other fella's submission was right on target. Search Wikipedia for "bulging capacitors" to get the inside scoop on this widespread problem. Major manufacturers are well aware of this issue, but fortunately for them it occurs some 2-years out'a the box, and after the warranty expires. This is one time I wish I'd bought the extended warranty! Anyway, I finally got my 5 caps from Ebay in the mail today. Specifically, they are 470uF 25volt 105-degree (use only 105's because some are right near a power transister heat sink---so I'll bet they get mighty friggin hot. After carefully replacing the old caps with the new (you'll need a solder ****** along with your solder iron), I reassembled, powered-up, and began to thoroughly enjoy the fruits of my labor. It's working like new once again. THE CAPS ON THE POWER SUPPLY BOARD ARE DEFECTIVE.
Posted on Dec 08, 2008
  • 1684 Answers
SOURCE: Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Posted on Jun 17, 2009
RodK
  • 5 Answers
SOURCE: Dell UltraSharp 19" LCD Monitor power button
http://en.community.dell.com/forums/t/18671898.aspx
Posted on Aug 18, 2009
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 16, 2014 | Acer AL Computers & Internet
Tcl tv model no dn2127h sound ok but no display
- Flickering screen
- Dim screen
- Slow start
Apr 11, 2014 | Televison & Video
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Oct 25, 2009 | HP W22 LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
One monitor clear the other not good fonts
I installed a better video card that supported dual monitors without splitting the signal.
Nov 19, 2008 | Advueu Technology ADV178T 17" Flat Panel...
6 mo old amw monitor A913B 19
Same Monitor, same problem. Solution: I changed the colors setting to 16 bit from 32 bit, and that cleared the problem. I then changed back to 32 bit and it still worked. How long, not known yet. So , go to display settings, find COLORS: and then change to 16 bit.
Jun 23, 2008 | Computers & Internet
After 30minutes and over,monitor display disappear
I had a similar problem with the same model; the cable connection into my computer was not good. Try fiddling or replacing the cable.
Oct 24, 2007 | Samsung 206BW Monitor
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
