Question about eMachines ET1161-05 PC Desktop
The power switch on my Et 1161 failed. I can not find a replacement part
I took the machine to a repair service and they were not able to locate a replacement power switch
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: I switched the operationg system of my et 1161-03
Hello there:
when you install a different operatin system expecially from vista to a nother one you might have to reload the drivers for the modem cause they will be removed if they have not been saved before the new operating system is installed . also you can go to device manager and do a scan for hardware change and see if it will recognize it there ok?
best regards michael
Posted on Sep 12, 2009
joecoolvette
  • 5660 Answers
SOURCE: ET 1161-05 IS NOT TURN ON THE POWER SUPLLY IS OK
If the motherboard is bad, generally the problem is bad Electrolytic Capacitors.
Visual signs of capacitor failure,
http://www.capacitorlab.com/visible-failures/
The eMachines ET-1161 uses an ECS MCP61GM-PM motherboard
http://support.gateway.com/s/MOTHERBD/Shared/4006203R/4006203Rmv.shtml
Who tested the Power Supply? You or them?
Has the test been performed to see if the problem is a bad Power On switch, or the Power Supply?
If you want to know how to perform this simple test post in a Comment.
Do you have access to a multimeter, or is a $5 to $10 multimeter in your budget?
Posted on Dec 10, 2010
SOURCE: how do I do a
most pc maker has an aditional partition called recovery...you can use it since the bios boot
press f1 for bios setup
pres f10 for recovery
press f12 for boot order all you need to do is select recovery
Posted on May 18, 2011
Is it possible to change the fuse in a sewing machine?
the only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Jan 14, 2016 | Sewing Machines
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
How did you took money for my accont on paypal I order nothing fom you
Contact PayPal, Customer service 1 (888) 221-1161 between 8AM-10PM CT, Monday through Friday and 8AM-8PM CT, Saturday and Sunday. "At PayPal, we have over 800 customer service representatives standing by."
Mar 07, 2015 | PayPal Computers & Internet
ET 1161-05 IS NOT TURN ON THE POWER SUPLLY IS OK THEY SAID THE PROBLEM IS MOTHER BOARD BUT IN NOT SURE .
Dec 10, 2010 | eMachines ET1161-05 PC Desktop
Very loud when switched on bissel quick wash 1970e
Your machine should be inspected. Please call us for Service Center locations in your area at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Jul 05, 2010 | Bissell 1770 Quicksteamer II Upright...
Can not remove any programs from system in control panel, when I try the system responds back with setup.exe has encountered a problem and will now be closing
I,d suggest A Virus-Malware et,c.
Run an antivirus software, if it lets you.
If you have also suffered with various pop-ups about security-Alerts et,c.
Then you,ve picked up A Virus-Trojan Horse-Malware et,c.
Run a scan, remove-heal infection et,c.
Failing this, re-install windows over itself, or Repair to replace any deleted/corrupt/missing Operating System Files.
Mike @ Compurepair.
Oct 22, 2009 | E-Machines T6524 PC Desktop
Washing machine not doing anything-replaced door
It appears your Lid Switch/Door Latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 27, 2009 | Washing Machines
Brake lights do not work All bulbs have been replaced.
Troubleshooting Procedures - Read Completely Before Beginning
(American Car) All Brake Lights Not Working
  • Check System Fuse: A fuse is used to protect the brake light circuit from amperage overload. If the fuse has failed it will not allow the electrical current to continue to the brake lights. To check the fuse, first locate the brake light system fuse in the fuse panel which is either under the dash or under the hood in the power distribution center. Connect the test light to a ground like an engine or dash bracket and turn the ignition key to the "on" position. Using the test light probe both sides of the fuse. If the test light illuminates on both sides the fuse is ok continue onto the next step. If one side of the fuse illuminates the fuse has failed and needs to be replaced. If the fuse fails as soon as it is replaced or when you apply the brake pedal the brake light electrical circuit is shorted to ground. Rarely a system short can occur, a car repair manual is needed to find the wiring schematic for the brake light circuit. Once the brake light wiring has been located inspect and repair as needed.
  • Check Brake Light Bulbs: All cars have three brake light bulbs that create the brake light illumination affect. If all of these brake light bulbs fail no brake light operation will occur. I know what you're thinking, you might say all three brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove any of the brake light bulbs to confirm the bulb is ok or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are ok continue to the next step.
  • Checking the Brake Light Switch: A control switch is used to connect the brake light electrical circuit. This switch is located near the brake pedal lever. Basic switches have just two wires, power in and power out to the turn signal switch. Use a test light that is grounded and with the key in the "on" position test for power at one side (wire) of the switch, then press the brake pedal while testing the opposite side (wire). It should illuminate the test light, if electrical power is connected through the switch go to the next step. If no power is detected through the switch the brake light switch has failed and replacement is required. If your car is equipped with more than two wires integrated into the brake light switch a car repair manual is needed to locate the proper brake light circuit wiring.
Jul 07, 2009 | 2000 Jeep Grand Cherokee
Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Nov 27, 2007 | Ricoh FAX5000L Plain Paper Laser
eMachines ET1161-05 PC Desktop Logo
24 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
