Question about Dishwashers
Miele dishwasher thumping noise - Dishwashers
2 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: dishwasher making thumping noise when in cycle and leaking
motor turns to cast the water around the dishes.that motor shaft is in close by a water seal.it must have gone bad allowed water on to the motor bearings which would be your noise.could be bad.open your bottem panel turn on unit and watch whats happening.when you see that decide what parts you will need ,check cost and think if thats what you want to do.God bless,tom
Posted on Jan 01, 2009
What is the most effective soap for thw Miele G870SC diswasher
the only dish detergents that work right now are the miele tabs, and finish has a product called finish all in 1 powerball. everything else on the market right now will leave your dishes dirty, and will leave residues behind making your glasses cloudy and your dishes dull. describe the noise better and i will try to help.
May 31, 2012 | Miele 24 in. G870 Built-in Dishwasher
Dish washer does not drain and has been progressively making noise over past year Would you have advice to offer on this problem
Regular thump-thump-thump when trying to drain?
Have you checked the little pipe in the bottom -- the one you can see running across for about 8 inches in the middle. It has a bend or two in it, and lumps sometimes get stuck. Fro $100 the service guy will pop it off and knock out the lump, or you can figure out how to unsnap it yourself. I haven't done it for years, but once you see it, it is fairly easy.
Aug 12, 2011 | Miele G880 Dishwasher
Have a Miele G1022i dishwasher (built in). It makes a humming noise when the power supply is turned on. All the indicator lights flash. Have tried cleaning out the drain and removed water from the salt...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Gene
Aug 05, 2011 | Dishwashers
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
Mar 30, 2010 | Miele G892SC SS Dishwasher
GE Dishwasher makes loud banging noise
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
Apr 06, 2009 | GE Dishwashers
Dishwasher making thumping noise when in cycle and leaking
Jan 01, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
