Question about Jetseal109-protection Beyond Need Shine Reason 1 Gal
Give three reasons why it is important that a tele-handler is no leaning sideways before attempting to lift or place a load
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Bought a new ewheel e36 discovered today there is no way to load it with lift. Looks as if in design they failed to remember that a lot of us with disabilty drive trucks and need a way to load our mob
The majority of lifts they have for scooters involve a flat ramp that mounts off the back of your truck. There are crane types but you said it doesn't have lift points; I imagine you could build some type of sling that you can put around it to lift it. Use a material like heavy seatbelt webbing.
Here are a few of the places that have the ramp style: Bruno Scooter Lifts Mobility Products United Access Harmar AL 050 Micro Power Chair Lift Lift Go
Feb 16, 2015 | Electric Wheels E-Wheels E-36 Three Wheel...
How do i change a lid switch on a kenmore top load washing mach
(For most)... Unplug machine at power (most important for any repair attempts).. Use a putty knife at about 2 inches from the front top corners where the top is attached to find the clips that hold the top to the rest of the machine. Once the clips are found, use the putty knife to push the the clips in while lifting the top up. The back of the top of the machine is held in place with clips that allow the top to be lifted far enough to set against wall behind machine without disturbing electronics. From this point, you should be able to see the switch and the manner in which it is clipped in. You will need your model number to order another. It is likely a Whirlpool or Frigidaire machine. Sears doesnt actually make anything. There may also be a part number on the part itself. Check eBay for replacement if you can wait for shipping.
Aug 05, 2014 | Kenmore Washing Machines
Armstrong 3 ton heatpump air handler. blower fan shuts down and wont turn on either in auto mode or fan on mode. next morning unit starts right up and runs perfect for a few days and then does it again.I...
With the limited information you have given, i will give you some steps to take to isolate the problem. Since this is an interrmittent problem you will have to wait for the unit to shut down again.
When the fan will not come on when it should be on, follow these steps.
IMPORTANT: IF YOU ARE NOT EXPERIENCED WITH WORKING WITH HIGH AND LOW VOLTAGE WHILE ENERGIZED, DO NOT ATTEMPT TROUBLESHOOTING!
1. Turn the thermostat fan switch to "on"'.
2. Remove service panel and find thermostat wire connections to air handler.
3. You must determine if you have 24 volt power thru the thermostat and to the air handler on the fan conductor. The fan conductor should be green.
4. There should be a connection of this green wire from the thermostat to the fan wire in the air handler.
5. This connection will have a wire nut at the connection.
6. Remove the wire nut and check for 24 volts at this wire connection.
7. To do this you must have a multimeter and know how to use it.
8. Place one meter probe on the bare wire connection and the other probe against bare metal in the air handler cabinet. You should get 24 volts. If not then you have a thermostat problem.
9. If you have 24 volts then put the wire nut back on the connection and follow the wire to the fan relay.
10. Take a insulated screwdriver and tap on the insulated portion of the relay several times.
11. If the relay is stuck this should free it enough to make it work.
12. If the fan comes on when you tap on this relay then you need to replace the relay.
This is the simplest way i can tell you how to troubleshoot your problem with the limited information i have about your system.
I am assuming you are mechanically inclined and understand the terminology.
If not, then get a professional to do this repair.
Sep 02, 2011 | Heating & Cooling
I have a Canon Sure Shot Tele dated around 1993. Its a film camera and I'm having trouble finding where to replace the battery.
If it's the TELE/MAX, the battery cover is on the left end of the camera (as viewed from the back). Slide the cover toward the back to open. It takes one CR123A battery, positive terminal up.
If it's the TELE, the battery cover is on the right end of the camera (as viewed from the back). Use a precision screwdriver to unscrew the two screws. Hook your thumb against the side of the battery and lift upward, then pull the battery out. It takes one 2CR5 battery.
Do not replace the battery when film is loaded.
Jan 05, 2011 | Canon Sure Shot 80 Tele/Date 35mm Point...
Replace rio rear brake light bulb
1. Behind each light you will see a small door in the back liner. Remove the 2 plugs in each door by pulling them straight out.
2. Gently pull back liner doors to expose rear of light assembly.
3. Remove three brass 10mm nuts from exposed bolts.
4. Slightly lift up bottom inside corner of light assembly, Pull back or sideways to center of bumper or trunk rear with wiggle movement to pull out rear light assembly. Takes a little while, but piece of cake.
5. Plug in the new bulb and put everything back in place.
Dec 07, 2010 | 2004 Kia Rio
Where do you place the floor jack to lift the front of a 1999 monte carlo?
The best place to try and lift is on the lower control arm as close to the tire as you can get the jack. If you are going to be working under the car then be sure to use a jack stand or some blocking to supprt the car in addition to the jack. If you are outside on the ground then be sure to place a piece of plywood under the jack stands. This prevents them from sinking.
If you want to lift the entire front end jack one side at a time and block it as you go. Do it in stages until you get the height you want. If one side is too high then the car will slide sideways as you jack the other side up. This is one of the reasons I prefer blocking to jack stands. Hope this helps.
Nov 10, 2010 | 1999 Chevrolet Monte Carlo
My A/C turned off. Still blowing air around. Hot air. Outside the A/C itself is not on. Any ideas???
if you open the bottom panel of your furnace you will find the controll board there will be 4 wires coming back from the thermostat and 2 going to the a/c the 24 volt hot wire for the a/c will be hook to the yellow wire coming back from the thermostat take them off the board and wire nut them together this will do the trick in many cases
Aug 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Jan 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Where is my a/c filter?
If your rooftop unit is self contained with no pipes leaving it except the condensate drain line there should be a narrow removable panel to access where the filters are located. If you have three pipes exiting the roof top unit two will go to an air handler located in the attic of the home. The filters will be located in the air handler.
Jun 13, 2008 | Heating & Cooling
Jetseal109-protection Beyond Need Shine Reason 1 Gal Logo
23 people viewed this question
Top Chemical Guys Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Chemical Guys Vehicle Part and Accessory Expert? Answer questions, earn points and help others
