Question about Gateway 7001433 Keyboard
Control key doesn't work with num loc on - Gateway 7001433 Keyboard
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Probook 6560b num keyboard doesn t work.Num lock is on...
your key is stuck you can get a key bosrd at wal-martit has a plug on iis that plugs into the usb port and might work
Apr 02, 2013 | HEWLETT-PACKARD ProBook 4520s
My HP Pavilion dv5-1004 nr when I type any letters it it just types numbers numerical. Ex. I type COMPUTER I get 12345678 Num loc is NOT on I have tried numerous version of the num lk..
For laptops that don't have a Num Lock key on the Key board, go to
http://windows.microsoft.com/en-US/windows-xp/help/on-screen-keyboard
You can pull up an onscreen KB that does have a Num Lock key and mouse click it....fixit
To open On-Screen Keyboard using your keyboard
  1. Display the Start menu by pressing Ctrl+Esc (or the Windows logo key). Move to All Programs by pressing P. Move to Accessories by pressing the Down Arrow key and then Enter. Press Enter again to move to Accessibility. Move to On-Screen Keyboard by pressing the Down Arrow key and then Enter.
Feb 16, 2013 | Computers & Internet
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
Our pound sign has disappeared and other characters have swopped position. We have bought a new keyboard but the problem is still there. Can you help please and is your help free?
Hmmm let's try this and if it doesn't work, we'll try something else.
It's possible that you have hit the Num Lock key while you had another key pressed. Try the following combinations, one at a time, to see if any of them work. Be sure to test each one before moving on to the next one.
CTRL and NUM LK
Shift and NUM LK
ALT and NUM LK
A lot of times characters will swap places if one of these combinations has been pressed, and pressing the combination again should switch it back. Let me know how it goes!
Aug 26, 2011 | Compaq Keyboard
Why would CNTRL-ALT-DELETE not work when I need to lock my computer? Where is the Num Lock located on this keyboard?
Num lock is located juz above the 7 num key on the num keypad. Try using control alt del key on another system and check if it works or not.
Aug 25, 2011 | Logitech MX 5500 Revolution Keyboard
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Use with usb adaptor
If the USB to PS2 adapter has 2 PS2 ports, make sure it is in the correct one, but this should not be the problem. I have heard that some PS2 keyboards do not work with some USB to PS2 adapters.. Too much trouble to get a USB keyboard?
Aug 14, 2007 | ORtek SKB-2200 (skb2200) Keyboard
Gateway 7001433 Keyboard Logo
13 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
