Question about Funai PY90VG DVD Player/VCR
Is there a list available of error codes for sylvania vcr?
What is the onn universal code for sylvania model 6719DFDF
0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 10, 2015 | Sylvania Televison & Video
Electronics 6 in 1 control codes sylvania tv DVD VCR combo
0456 [0458 0227] [0458 0236]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Apr 07, 2012 | Televison & Video
Need code for universal remote for sylvania srd3900 dvdvcr
Check these codes:
Mar 29, 2012 | Sylvania SRD3900 DVD Player/VCR
I put in a vcr tape and get err 2 this is a dvd/vcr player made by sylvania. the dvd player works fine
The instruction book will give a list of Error Messages and their meaning.
If you've lost the book go to Sylvania's website where there will be easy to follow steps to either viewing the book for the device or downloading and printing it.
Sep 20, 2011 | Sylvania DV220SL8 DVD Player/VCR
I need the programing code for a sylvania tv
Give these a try.
SYLVANIA ..........0062 0004 0009 0135
......................0189 0183 1141 0227 0456
......................0008 0068 0075 0141 0161
Or these:
Sylvania
004, 006, 008, 019, 062, 068, 069, 074, 075, 076, 077, 088, 116, 161, 183, 184
And incase you need the programming instructions, here ya go!
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Aug 22, 2010 | GE JASRM24912 Remote Control
Where can I get a remote for a Sylvania 6313CE  13" TV/VCR
go to walmart and get a $10 rca universal remote and under the codes list go under vcr not tv and program it to vcr/aux
Jul 11, 2009 | Sylvania 6313CE 13 in. TV/VCR Combo
Rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
Feb 22, 2009 | RCA 3-Device Universal Remote with...
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Funai PY90VG DVD Player/VCR Logo
13 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
