Question about Panasonic MC-CG902 Canister Vacuum
I just bought my Panasonic MC-CG902 vacuum cleaner two and half months ago. For no apparent reason, the canister motor doesn't work. The power nozzle is working, so it is not the outlet, but there's no suction because main canister motor is not running. There are no clogs in the lines and filters seem to be okay.... I have unplugged and waited a half hour multiple times, in case something needs to reset, but it still doesn't work. What is wrong with it and how can it be fixed?
reddevil6
  • 1673 Answers
SOURCE: not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Posted on Feb 13, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
ukvacfan
  • 328 Answers
SOURCE: Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Posted on Feb 27, 2009
ThinkVacuums
  • 144 Answers
SOURCE: We have a Kenmore canister vacuum cleaner and the
the problem could be with the power head itself or the hose providing the power. If you can turn the unit on from the handle, then its not the hose and you need to get a new power head..
Posted on Aug 14, 2009
renevacdoc
  • 84 Answers
SOURCE: i have a panasonic mc-ul975 vacuum that works
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Posted on Nov 05, 2009
How to change the belt
usually reading the directions helps .
Jul 27, 2015 | Kenmore 6 Canister Type C Sears Vacuum...
HOW TO CHANGE A BELT ON A MC-V7305
Make sure vacuum is unplugged. Lay. Vacuum upside down and remove Bottom plate. Pull brushroll from nozzle housing, pull metal end caps from brush and remove any hair and debris. Put new belt around motor shaft then around brushroll. Put one hand on each side of belt and pull brushroll to stretch belt far enough to drop brushroll into position. Make sure brush spins freely. Install bottom plate. Make sure brushroll turns freely, if not, make sure bottom plate is not restricting the belt before you turn the vacuum on. Repeat the process in 6 months. You may be surprised to see how much a belt stretches and loses elasticity after it's been on your vacuum for 6 months.
Feb 08, 2015 | Panasonic Vacuums
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Need owner's manual for Panasonic MC-9420 canister vacuum cleaner
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Feb 21, 2010 | Panasonic Vacuums
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Panasonic MC-CG902 Canister Vacuum Logo
48 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
