Question about Video Cameras
C 13 02 error sony
I can't record video because when i click on record button it is showing disk error,remove disk.what can ido for it?
3 Suggested Answers
  • 80 Answers
SOURCE: Sony DVD+R records and then has disk error and
To retrive your data from any corrupted media please try any of the link below:
DriveSavers Data Recovery Services: http://www.DriveSavers.com
sonystoragesupport.com
Posted on Aug 11, 2009
ddshah24595
  • 33 Answers
SOURCE: Sony HDR-xr 150 is showing data error whenever I play back the recorded videos
Connect the camera with pc and try to check for error with any program like tune up or other online utilities... or if you have data card in it and you can open it in PC than simply copy your recorded videos so that you have a backup first. than you can freely show camera to any service center..
Posted on Sep 16, 2012
What can ido about a 80010154 code
There is 3 things that you can do about your PS3 code that is showing you up.
  1. Pick up your PS3 and throw it out of door.
  2. Send your PS3 to Sony support and pay them about $200 and that is also not sure that they will fix it.
  3. Last but in my opinion best option is to repair that code error your own.
How can you fix it yourself?
There is lots of guides, step by step videos, PS3 repairman support, private member access where you can fix your PS3 at your home without costing that much. Click here for guide
Sep 22, 2013 | Sony Playstation 3 (PS3) Console
Tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 | Cameras
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
In trying to download video from our cam corder (Sony DCR-SR85) to our PC we get the following message 'Document management information can not be located" and we are unable to download the video files....
Different ways to transfer video:
Transfer the video to the computer using one of the following methods:
Use the Import pictures and videos option.
    1. In the AutoPlay window, click Import Pictures and videos using Windows .
    2. In the Import Pictures and Videos window that appears, click Import Settings .
    3. In the Import Settings window, assign the location on the computer where you want to copy the picture and movie files.
      • Next to Import images to click the Browse button and then select the desired folder (for example, My Pictures ).
      • Next to Import videos to click the Browse button and then select the desired folder (for example, My Videos ).
    4. Click the OK button.
    5. In the Import Pictures and Videos dialog box, click the OK button.
    6. Click the Import button.
  • Use the supplied Handycam┬« Utility application.
    1. Start the Handycam Utility application bundled with the Sony® Picture Utility software.
    2. In the Handycam Utility window, click to the select the type of files you want to transfer: HD movies , SD movies or Pictures .
    3. Click the Import button.
  • Copy and paste the video files from the Removable Disk window that represents the camcorder.
    1. On the computer desktop, create a new folder.
    2. If the Removable Disc window is not showing, open the My Computer window and then click to select the Removable Disk icon.
    3. In the Removable Disk window, click to select all the folders and files listed.
    4. On the keyboard, press the CTRL+C keys to copy the folders and files.
    5. Open the new folder that you created.
    6. In the new folder, press the CTRL+V keys on the keyboard to paste the folders and files into the new folder.
    7. Rename the new folder.
Oct 21, 2010 | Cameras
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I recorded a video in my sony handycam dvd and its haf recorded.now it is showing a msg that do u want to make it recordable.i want to keep the previously recorded video and continue recording.what do i do...
The possibility of this varies from handycam to handycam but it is most likely related to the type of disk you are using.some disks can only record one session. it is important to read the instructions that came with the disk.generally disks marked 'DVD-R' can only record one session whereas disks marked DVD-RW can record several sessions and can even be erased and recorded on again as new.
pse reply if this helps you
Luwangula
Sep 10, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
C:13:02, Disc error. Remove disc. Recording disabled.
I'm sorry to say, that all disk manufactures are not the same. If you used a "no name" disk, then the quality may not be what you want, although in rare cases, even good companys like Memorex can make a bad batch or two. Just try another disk. Let me know if that works by leaving a comment. If this works for you, rate my solution a fixya!
Rob
Jan 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Im getting a Hard Disk error
ill try to be a little clearer
Disk is not full, i never wait till theend to unload my videos. I try to derfagment it every time I unload my videos.
This problem happened to me twice, luckly was able to recover.
I plug the camera to the USB port, computer sees it. I start copying files to my comp using the camera software, than everything freezes. I unplug the camera switch to the recording mode and it showes me "disk full error" , "hard disk error". At that time the computer stops seeing the camera.
I spend good half hour messing with it, turning it on and off and playing with buttons. After a while I get it to work and my recordings show up again.
I suspect a conflict with the software or possibly hard disk is over heating.
So far I was able to live with this problem.
Cheers
Jul 25, 2008 | JVC Everio GZ-HD7 Camcorder
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
