Question about Jandy Pool & Spa
FL 0 code on my jandy lite 2
Replaced the pressure switch..no help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Is there water dripping from copper tube if not clean out copper tube and poke into where goes into heat exchange they get calcium
Posted on Dec 01, 2014
3 Suggested Answers
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
john224
  • 1378 Answers
SOURCE: Jandy Lite 2 pool heater
Thank you for posting your question here on Fixya.com.
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
Jandy lite 2 fl 7
Pressure switch will do exactly what you checked for, when the pump is not running. voltage on one side but not the other is normal when the pump is off. With pump on & operating, you should have voltage on both sides. One lead on the common wire at the transformer and the other checking the flow of electricity across the switches.
It sounds like your roll out sensor/fusible link is burned out. This burns out (open circuit) because of a "Reason"!!! The heater needs to be checked by a professional service company. Heat exchanger in most cases is Sooted & needs to be cleaned/desooted.
good luck
May 25, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Fl 7
get pump working first see if you have 24 volts to pressure switch both sides if so check the rest of the safety circuit
May 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Fl 0 fault
open safety circuit make sure fusible link is good and pressure switch is good
Apr 18, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
FL 7 is showing on computer screen. What does this mean?
Either the pump is not pumping enough water through the heater to activate the pressure switch, or the pressure switch or its wiring has failed.
Replace pressure switch .
Mar 23, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2 - FixYa
check the fuses from the red wires if blown replace if ok replace ignitor
Aug 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I have a Jandy Lite 2 heater and I keep getting an error message FL 0. What can I do to get this heater working?
check the copper line to the pressure switch if ok check pressure switch should have 24 volts ac both sides if ok check rest of safety circuit
Aug 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 LP 400 will not activate the ignitor. Power is on.
Somewhere on the panel or inside there shpuld be instructions telling what 4 flashs represent...
Could be a high limit that needs reset, a rollout switch the needs reset, or a pressure switch if you have a vent blower on that unit...
heatman101
Apr 24, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool & Spa Logo
116 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
