Question about Roper REX3614KW Electric Dryer
Dryer drum does not turn and motor does not come on byt top of dryer is hot
Serial No. M10830379 Type No. DWJR-ELE-2406026-FM54
3 Suggested Answers
SOURCE:
TheMobilian
  • 8220 Answers
SOURCE: My roper dryer was not turning ,when I would start
7b0099b.jpg MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 10, 2010
Daniel S
  • 4323 Answers
SOURCE: Model RED444osQo TYPE: DWJR-ELE-240626-FM54 Dryer would not
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the timer motor that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 05, 2011
My DWJR-ELE-2406026-FM54 dryer is getting hot but not drying the clothes. Even after 3 cycles they are still damp, not warm at all. What would that be?
Ventilation, check the vent hose and the vent pipe and the damper outside for restrictions probably clogged with lint. If the moisture can’t escape the clothes won’t dry.
May 10, 2018 | Dryers
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
I just bought an older whirlpool dyer (MOD wed5300sq0 type dwjr-ele-2406026-fm54) and it spins counterclockwise. Is that an issue? The heat is blowing out of the house in the correct direction but I didn't...
The drum on the dryer is powered by an ac motor. You cannot change its direction of rotation by changing lead connections. AC has no positive or negative leads. It must be OK as is
Oct 29, 2014 | Dryers
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me melissamaemartin@yahoo.com I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
Dwjr-ele-2406026-fm54
Hay Kirk , most likely your door switch needs to be replaced if that doesn't help test all three fuses for continuity . good luck APPLIANCES R EN
Mar 02, 2013 | Whirlpool Inglis IP8200 Dryer
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
The stock number is IED4400SQ0 The type is DWJR-ELE-2406026-FM54 The problem is that my dryer isn't working. I've checked all of the electrical wiring and they're properly working fine....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 16, 2011 | Whirlpool GEQ8858H Dryer
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
Roper REX3614KW Electric Dryer Logo
252 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
