Question about Bowflex TreadClimber TC10
Drive belt broken new belt too short - Bowflex TreadClimber TC10
Lg 6.5 fuzzy logic no spin but still drains
could be belt broken or slipping internally. if you hear the electric motor still running, you may have broken belt. not sure what type washer you have. most of them have scews fastened the body or access panel behind. if the belt drive is broken best get the part number for your washer model and see if you can get one order thru the appliance's store or online. made sure you get the correct information or you will have too short or too large belt.
Mar 02, 2015 | LG Washing Machines
1991 sun dance dies in middle of road will not start. The check engine light blinks 2 short 3 quick. Could this be a timing belt?
Your timing belt could be broken or perhaps the Drive chain that drives the two balance shafts behind the timing belt
Dec 15, 2012 | 1991 Plymouth Sundance
I have an 1997 Audi A4 1.8 SE. Towards the end of a long motorway drive the power steering failed, a few miles on from there the engine started overheating and both the coolant and then the battery light...
CHECK FOR BROKEN LOOSEN DRIVE BELT.IF DRIVE BELT BROKEN YOU WILL LOSE POWER STEERING, WATER PUMP AND ALTERNATOR STOP TURNING IF LOSE DRIVE BELT. IF DRIVE BELT BROKEN.CHECK FOR FAULTY DRIVE BELT TENSIONER.LOOK FOR SEIZED WATER PUMP, ALTERNATOR OR POWER STEERING PUMP.REASONS DRIVE BELT BREAKS.
Jun 07, 2011 | 1997 Audi A4
Craftsman 17.5 drive belt broken, purchased a gates 6885 1/2 x 85, will this work? seems too short.
85" is too short. It is part number 160855. It needs to be 1/2" X 95". Here is one shown and cross- referenced on Amazon.com. Post back if needed. We can give you tips on how to install. Here is the drive (transmission belt).
http://tinyurl.com/3hn54ff
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Volt light is on
Your lucky you didn't hydro lock the engine. You probably shorted the alternator and its not putting out amps needed to operate most accessories on the vehicle (like power steering pump). Have the charging system checked out. Replace the items the repair shop tells you to replace.
Jul 19, 2010 | 1998 Buick Park Avenue
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Will not spin
make and model number for accurate diag, but most common problem is broken wqasher tub drive belt, turn washer on its side and check for a broken belt.
Sep 27, 2009 | Washing Machines
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Bowflex TreadClimber TC10 Logo
19 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
