Question about HP W19b LCD Monitor
My hpw19p monitor display screen will not stay on and I have to click on the power button for the display screen to come up but it only stays on a few second before going black screen again, the power
Everything is operation, checked all the plugs and rebooted the whole system and yet the monitor still gives me a black screen unless I click the power button on the monitor which by the way is on, and only then will the display screen come up but only for a second before going black again. HELP!
SOURCE: power button stay on for 2 seconds, black screen,no picture
It's less costly to buy a new LCD monitor than having it fix.
Posted on Dec 23, 2007
SOURCE: black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Posted on Oct 12, 2008
SOURCE: I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
Posted on Dec 09, 2009
ruwidperd372
  • 279 Answers
SOURCE: Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Posted on Apr 10, 2010
Slasher_X
  • 767 Answers
SOURCE: The monitor will not stay
See my tip here: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
Posted on Apr 17, 2011
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
Hello, I have a Samsung 2493hm monitor, earlier this week I turned on my computer to see nothing. My screen remained black. The power button stays on and it never cuts off, so i'm thinking it's a...
With my Samsung 2493hn, I used HDMI. Use auto detect, on front next to secondary power. Not the main power switch on back of unit. Windows 10, click notification button lower right on Taskbar. Click on Project, then choose which option.
If when you power on Monitor without white squares with HDMI, ANALOG, DIGITAL printed in each then yes sounds like back light.
Aug 02, 2017 | Samsung SyncMaster 2493HM Monitor
1. Restart your PC
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
My monitor will go on but it will not stay on
Either sleep timer is on or the refresh rate is set higher then the screen to handle or scheme is not set for laptop.
you can right click on main screen to access display and advanced options.
Oct 23, 2009 | Acer AL1715 17" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Hp pavillion dv4040 us problem with monitor ''button''
ok go into control panel.double click display.in display properties click on screensaver;then click on power.in power options properties select never in all the fields.then click advanced and select options in power buttons.e.g. when i close the lid on my laptop select do nothing.same for sleep button(hybernate)...
Nov 23, 2008 | HP Pavilion dv4000 Notebook
HP W19b LCD Monitor Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
