Question about Jabra BT135 Bluetooth Headset
Jabra sport showing pink blinking light - Jabra BT135 Bluetooth Headset
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Why can't I turn on my Jabra sport after charging?
    Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
    Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
    May 23, 2014 | Jabra SPORT Earset
    Jabra sport will not charge
    Same problem did you call the 800 number?
    Dec 09, 2011 | Jabra Radio Communications
    How to pair with cell phone Lost manual for jabra bt530
    hold all three buttons together ie power and volume ,three color lights will blink, this resets the jabra headset, then try pairing again , when pairing the lights should not slow blink. it should stay constant or random flashing.
    Dec 22, 2010 | Cell Phones
    Jabra BT2050 blinks three times; doesnot pair up
    Hold round center button for 10 seconds, light will stay on and be in pairing mode.
    Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
    Connecting two devices on BT3030 headphones
    A method to do pairing in "the second channel."
    1. Trun off BT3030 first.
    2. Continue pushing the power button till "Jabra" mark turns on pink next.
    Attention: Continue pushing the power button after "Jabra" mark became the blue.
    Mar 11, 2009 | Jabra BT3030 Wireless Headset
    Steady Red Light
    From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
    "My red light won't go off even though I charged it all night.
    Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
    This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
    "Doesn't anyone from the Jabra manufacturer check this site?"
    NO (especially not for discontinued products)
    Oct 05, 2007 | Jabra BT150 Wireless Headset
    Jabra BT135 Bluetooth Headset Logo
    75 people viewed this question
    Top Jabra Radio Communications Experts
    TO Lady
    Greg Cann
    Greg Cann
    Michael Vincent Cruz
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
