Question about GE Freezers
New gasket required for lid of eurocold freezer C4AE the rubber seal has gone soft and lid sticks with ice build up
  • 833 Answers
SOURCE: Chest freezer lid sticks in closed position
Yes, use silicon lubricant.
Posted on May 27, 2008
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
  • 56 Answers
SOURCE: I have an upright freezer and replaced the rubber
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Posted on Jun 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: Ice collecting under bottom of Freezer drawer
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Posted on Jul 04, 2009
heatman101
  • 43501 Answers
SOURCE: meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
I'm making a wooden ice chest using an igloo 150qt ice chest. can I cut that lid in two and customize it to have a glass top?
Hello;
You are a man after my own heart.
Consider using a no shatter proof clear plastic. It is safer and easier to work with. Select an open cell gasket material (Soft rubber) for your door gasket. On the out side of your doors, using a good adhesive make a frame with steel strips to add weight to get a good seal. If you can, leave a 1" gap all round the cooler and make it air tight, air is your best insulator. You have a air gap in your hot water tank.
Glen Burnie, MD
443-306-1362
Oh, what kind of beer are you using?
Dec 19, 2014 | Freezers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Door not sealing properly. Visible gap in the upper left corner. Notice ice building up near gap. How do I fix it?
dear sir,
i think your freezer,s door there is one rubber between door and body it has been turn and damaged its need to replace. after change this rubber your who is sealing your freezer,s door your ice problem will be solve.
hope answer the question
thank you
please vote!
Jul 08, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Top shelf ices over
This could be because of the thermostat not sensing when the fridge reaches its set temperature and as a result of this the compressor will keep on running and build-up of ice will occur.Second cause of the ice might be the door rubber seal not sealing propperly.
Hope this helped.
Regards
Andre Nagel jnr
AQS Industries cc
Mar 29, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 | Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
37 people viewed this question
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
