Question about Garden
Noma D2450010 Snow thrower Auger wont stop spinning when disengaged
I have a Noma D2450010 5hp Snow thrower. I replaced the V belt and noticed that the auger doesn't stop spinning when its disengaged. I noticed that there is an arm underneath the belt that is just laying there basically doing nothing. There is nothing attached to it, so it seems it doesn't serve a purpose. When I look at the parts diagram on the sears website, the part looks to be The Brake Arm Rod. Could this be my problem. It also looks like there maybe should be a TENSION spring attached to this, which like I said thaere is nothing on mine right now. Can you tell me how to fix this and also should the Vbelt be under this arm or over it
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
trippssmengi
  • 76 Answers
SOURCE: auger on my snow blower won't turn.
First take a look at the shear pins they will be located on the augers going thru the auger and auger shaft, if they look ok then you need to take the belt off, with the belt off try to turn the im peller by hand. If the impeller does not turn then you need to look to see if something is stuck in the impeller or in the auger. If nothing is stuck in between anything then I would have to say it's going to be the gear box. If the impeller turns then look to see if the auger is turning also while turning the impeller. If the auger doesn't turn then it's probably the gear box. If it does turn then you have an issue at the pulleys
Posted on Jan 07, 2009
  • 183 Answers
SOURCE: Auger turning slow. Auger turns initially but
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
Posted on Dec 14, 2009
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
heatman101
  • 43501 Answers
SOURCE: My Yard Machines snow blower
The bearing can be a bugger to remove....and it sounds like the bearing may also be bad... so you will want to replace that also...
To get it off make sure that the set screw(s) are backed out with an allen wrench...the set screws will be in a small hole in the lip of the bearing....an allen wrench is a six sides wrench that comes in many sizes... the screws may also be a metric size...
then to remove the bearing you will need to use a gear puller that will grab the bearing equally with thre jaws and the use the shaft for leverage as you turn the screw to pull the bearing off of the shaft...
You will bugger up the shaft if you keep trying without the proper tools and then you will really have a mess on your hands...
heatman101
Posted on Dec 21, 2010
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
Noma auger wont stop spinning when disengaged
Sounds like either the auger belt is jammed to tight or handle mechanism to engage/disengage is stuck in on position. I would remove belt cover to inspect auger belt and pulley first, then remove bottom cover and inspect auger engage apparatus. I think once you inspect the problem will be self explanatory. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 18, 2014 | Garden
Need manual for Noma snow thrower D2045010
I would suggest taking a look at this Noma Snow Thrower Manual. Well I just noticed it isn't quite the right one, but maybe it will work?
Feb 03, 2013 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
