Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
Adjust blower carburetor husqvarna - Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
5 Suggested Answers
  • 211 Answers
SOURCE: Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Posted on Dec 14, 2008
  • 2239 Answers
SOURCE: what is the factory (h) and (L) carburetor adjustment for husqvarna chainsaw
We would need to know what model we are refering too, a good rule of thumb is 1 turn out on each, then fine tune from there, some models are different to this.
Posted on Jul 08, 2012
  • 3 Answers
SOURCE: What tool is needed to adjust the carburetor on a husqvarna 240 chainsaw
The splined Poulan Carb Adjustment Tool, 530035560, which was readily available for less than $20.00 before 2013, has become scarce and bottom the feeders are price gouging. Check ecrater.com and curtschainsawparts.com. I just received one and it is the quality item at very reasonable price, $14.00
Posted on Jul 06, 2013
Terry Corrow
  • 10875 Answers
SOURCE: How do i adjust the carburetor on a husqvarna 18h hedge trimmer thanjs
you shouldnt need to,if it wont run right then your carb needs to be cleaned or gasline replaced,ethanol kills carbs and gaslines.
Posted on Apr 03, 2015
My Husqvarna 130 BT leaf blower starts fine but loses power win Itry to use it ????
it sounds like the carburetor needs adjustment. You may need to bring it to a small engine repair clinic for servicing.
Apr 03, 2017 | Husqvarna Garden
Weak blowing husqvarna 130bt
Your carburetor needs an adjustment on the H needle which is the high. Find the needle on the carburetor if this carb has both the L and the H needles on it. While holding in the trigger turn the H needle in quarter increments counter clockwise until you hear the engine accelerate.. your unit is running too lean
Nov 19, 2015 | Husqvarna Garden
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
What are the screw adjustments for the carburetor for 125B Grass Leaf Blower?
These should be set by a certified dealer using a tachometer. It is against Federal law to tamper with the adjustment screws. You can also damage or destroy the unit if they are not set properly.
Jun 13, 2014 | Husqvarna Hand Held Blower 125 B Grass...
Where are adjustment screws on 125bt
They are on the side of the carb however there is a special tool required to adjust them , they have no slot in the top to fit a screw driver, the tool is part no, 530035560
Jul 06, 2012 | Husqvarna 125bt 25.4cc 2-stroke Gas Backpk...
My husqvarna 125bt blower chokes out when given full throttle
Most likely the high speed needle on the carburetor need to be turned in(clockwise) just a little . But it could be other things also.
Jan 30, 2011 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Carb adjustments for weedeater model gb1 22v
If the blower has ran ok in the past but now not so good I doubt it is the adjustment to the carburetor, I would suspect bad fuel or old fuel first. Empty the blower of gas, pump the primer ball until all of the fuel is pushed through the carb and back to the tank. Add fresh fuel with a premium grade oil (I use gold spectra) and try it again, carburetors typically do not get out of adjustment. I own a 125 BT and have never had any trouble with it other than skunky fuel left over from the previous season.
May 26, 2009 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
96 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
