Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
Delonghi exam 5500 milk not hot
Milk not hot anymore??
2 Suggested Answers
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Delonghi ESAM 5500 no hot water/milk just says "Heating Up, Please Wait"
Apparently the heating element has gone to that place where they can not be fixed .
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
How can i fix the hot milk function on delonghi coffee machine?
The voice from the grinder ??
If so that's men you pushed the cappatino
Try to push the same button twice you will read
Further and steemar
Apr 06, 2015 | DeLonghi Magnifica Coffee Makers &...
Delonghi 3500s coffee machine not producing hot water or steam from water outlet/milk frother
Hey Everyone,
I had this exact same problem.
Check out my video of how to fix it.
Video: https://youtu.be/_SbGiD4LeCc
Hope it helps!
Jun 25, 2014 | Coffee Makers & Espresso Machines
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Parts for gran dama 6600
You can order the parts directly from DeLonghi. They stock all the replacement parts. I ordered a milk carafe from them.
Sep 22, 2012 | DeLonghi Esclusivo Gran Dama EASM6600...
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
DeLonghi EAM3500 ..milk wont come properley
We had a similar problem and it required a replacement coupling block. Part No-111 on the Delonghi part breakdown pdf
Jun 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Milk container doesn't heat milk..only the steam is released.
I was told this was a problem with the O rings on the machine (you need to keep these clean or replace them (if necessary) to keep the milk container working properly).
I did this and still had the same problem. Turns out the top on the milk container needed to be replaced. It's $20 from Delonghi but at the time of this writing is out of stock (I have waited three seeks so far and Delonghi is supposed to be escalating my request).
I finally got frustrated with the whole thing and completely disassembled the milk container top (there are a total of 5 screws and you need to remove the froth control slider to get to one of them) and gave everything a good cleaning. Pay attention to the small orifice on the inside of the chrome tube that the milk comes out of. Using a dental gum cleaning brush or similar sized brush and some hot soapy water should get the dried milk residue out. Inside the top is also a rubber piece that the froth regulator inserts into. Reomve this rubber piece and clean thoroughly. Make sure and clean all other areas inside the top with hot soapy water. Make sure to look the top over well as you disassemble to be sure note all component positions for reassembly. Make sure when reassembling that the cleaning button and its spring are reassembled correctly. The small red O ring on the end of the cleaning button's rod should be cleaned well and the small tube into which it inserts should be free of any milk residue. One last item to check is the rubber bushing that rubber milk uptake tube inserts into is clean and making a good seal. Note that this bushing should make a good seal on both sides (the side the rubber uptake insrts into and the side the upper side of the top inserts into. Make sure all parts are reassembled correctly. In general if you clean and rejuvinate all areas that need to make a tight seal you should get good results. I have no experience here but it would be my observation that even with a good thorough cleaning job the results may not last a real long time as it seems that parts in the top show wear after about a year and a half of daily use. In my oppinion the purchase of a new $20 top makes sense, but if you can get one or don't want to wait you can spend the 30 minutes to do the above cleaning. Because of apparent backorder issues at Delonghi this may also be a good idea to buy upfront. Make sure to include the 5 O rings in the order ($1 each) to avoid paying two shipping fees. I have found one of the O rings at Lowe but was unable to find a few of the sizes (smaller than Lowes sells).
Aug 08, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
21 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
