Question about Beko Ovens
Main oven won't heat up but the top oven and hob do
SOURCE: Main oven not working
element needs replacing
Posted on Mar 14, 2008
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
Why does my premier double gas oven not supply gas to main oven and heat, striker works and clicks but no gas, top oven and hob working ?
IF IT HAS A HOT SURFACE IGNITOR FOR THE OVEN THAT IS MOST LIKELY YOUR PROBLEM EVEN IF IT GLOWS IT CAN STILL BE WEAK
Nov 14, 2014 | Ovens
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I have a zanussi buit under double oven the main oven all the lights come on but no heat. it worked yesterday well top oven works and so does gas hob
If it is an electric oven and fan assisted, and the fan is working o/k, then you need to fit a new oven element, located behind plate at rear of oven.
Please rate my solution.
Thanks.
Nov 12, 2009 | Ovens
Hotpoint ew83p oven has no heat
Job done..
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Ovens Logo
12 people viewed this question
Top Beko Ovens Experts
ray gallant
Renee Knafel-Bullock
Are you a Beko Oven Expert? Answer questions, earn points and help others
