Question about Samsung Washing Machines
Samsung wa13r3 toploader washing machine. when lid is closed it still gives error message that lid is open. sometimes it works if I wiggle lid a little but other times especially lately it doesn't help and sometimes the machine starts by itself after couple of minutes.
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
  • 26 Answers
SOURCE: Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 19, 2008
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Maytag washing machine MAH5500BWW gives me an Lr error message
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&
Posted on Oct 01, 2010
I have a GE profile topload washer PTAN9455MGG displaying F4 Error code and no answers.
tou can test this by jumping the lid switch , to do this you cut the 2 wires and twist them together . now this will not permanently fix this it will run a cycle and then fault out again . It has to detect a open and close of the lid . the switch is cheap and its a easy repair
Feb 18, 2013 | Washing Machines
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
Why does my toploader washing machine just shut down as though it is not getting electric current
does it fill with water and then nothing?if so it sounds like the lid switch is broke,open and close the lid a few times,open it a few inches and close it,if you don't hear a clicking sound the lid switch is bad.and it will be like the washer is dead after it fills
May 15, 2011 | Kenmore 14102 Top Load Washer
I have a 5 month old samsung steam front loader that gives an error message of d5 . What does it mean and how do I fix it
the door is not sensing that it is closed. open it and re close the door again, make sure it is closed all the way, if it is and it still gives you this error, unplugg the machine, close and open the door again, and plug it back in and try again. if this doesn't work, you'll need to have a repairman take a look at your washer.
Mar 01, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
We are getting the oL message even when we wash a light load or even run the machine empty. The machine seems to be spinning, but cuts off with the "oL" message sometime between the rinse and...
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Feb 18, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a Maytag LA212 AND a Maytag A8120 washers that will both fill but then do nothing else. The A8120 I got first and it just started this behavior last night then then today someone put out the LA212...
I used to have 2 laundromats full of toploader Maytags... these will fill and do exactly what is happening to you if the LID SWITCH is not activating. Open and close the lid and listen for a clicking sound. Look a the rear edge of the lid... there is an indentation that is supposed to activate a small white switch in the that's attached to the top of the machine. Many times the lid will simply get bent.. someone sitting on the lid, standing on the lid... will be enough to throw it out of whack. Close the lid and push on the center of the closed lid... will the machine work? Or carefully push a flatblade screwdriver tip between the lid and the switch to see if you can get it to activate. Solution: Open the lid and apply firm pressure on the lid towards the back of the machine, while with the other hand push DOWN on the back edge of the lid...right where the indentation for the switch is... if you give it a slight tweak...you'll probably be back in business. One other thing, if the lid switch isn't clicking...replace it.
Sep 12, 2010 | Maytag HAV2557 Top Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check lid switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Error code 105
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Jan 29, 2009 | Washing Machines
LG toploader washing machine alarm signal Lid Open.
The lid switch is bad, not making contact.Replace switch or see where it is not being contacted by the lid or hindges when the lid is closed.
Jan 04, 2009 | LG KU990 Viewty
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
