Question about Lexmark C762 Laser Printer
925.02 service wrong fuser lamp error lexmark x204n
  • 8 Answers
SOURCE: I have an x543 Lexmark printer and there is an
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
Posted on Feb 04, 2010
don_farr
  • 1018 Answers
SOURCE: When I turn on my lexmark x204n it gives me a 900
A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
Don
Posted on Mar 10, 2010
SOURCE: "900 firmware error"
"900 firmware error" on our Lexmark X204n printer. how do we fix it?
Posted on Sep 07, 2010
tballone
  • 126 Answers
SOURCE: i have a Lexmark c540n printer that has the fuser
you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
after you replace it let me know if you still receive the error.
Posted on Oct 19, 2010
mariolands
  • 2296 Answers
SOURCE: Problem: lexmark x544: 122.03 service fuser error
The Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 10, 2011
What does the error Lexmark X204N error 31.05 mean?
Try cleaning the toner contact springs with cloth damped with a little alcohol it will make continuity more sensitive to the toner cartridge chip
Dec 15, 2016 | Lexmark X204n 4-in-1 Laser Printer
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
How to fix935.12 services mirror monitor for lexmark x204n
call 1-800-LEXMARK (800-539-6275) if still under warranty you will get a repalcement.
Feb 06, 2015 | Lexmark X204n 4-in-1 Laser Printer
Lexmark x204n
Lexmark x204n 931.01 error
Nov 04, 2013 | Office Equipment & Supplies
Lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
Sep 25, 2011 | Lexmark T644 Laser Printer
X204n lexmark,900 firmware error to continue,
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
Jul 27, 2011 | Lexmark X204n 4-in-1 Laser Printer
920.06 Service Fuser under temperature while printing
If the printer is out of warranty, your next option is to change the fuser which costs around $300, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Feb 05, 2011 | Lexmark X204n 4-in-1 Laser Printer
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
Sep 10, 2010 | Lexmark C530dn Laser Printer
When I turn on my lexmark x204n it gives me a 900 firmware error how can I get rid of it and what does it mean?
Don
Mar 10, 2010 | Lexmark X204n 4-in-1 Laser Printer
Jan 21, 2010 | Lexmark X204n 4-in-1 Laser Printer
Lexmark C762 Laser Printer Logo
348 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
