Question about Exercise & Fitness
Schwinn manual My console on my 450 Eliptical Trainer is malfunctioning
2 Suggested Answers
oakrunner09
  • 14 Answers
SOURCE: need manual for schwinn eliptical trainer
Here is a link for the manual you need. Please rate me.
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_430_OM_RevA_web.pdf
Posted on Jan 30, 2011
Schwinn 450 turns off after 5 seconds
The symptoms seem to be either stopping or displaying the "keep striding" message after 5 seconds, depending on the program/course in play. The most likely reason is the speed sensor is not working. A call to Schwinn support suggested opening the frame by pulling the crank to get to it. In my case, I found a simpler step to try first, and in my case it resolved the problem. Note: this may not be applicable to all models - I have a 450.
Remove the two screws holding the storage bin (at the base of the console mast) in place. See if the speed sensor is properly positioned. I found that it had become detached from the bracket and was just lying on the inside. I glued it back to the bracket (using a flexible adhesive good for plastic and other materials), and lo and behold, everything is working!
If this doesn't work, then your speed sensor is probably bad and it's on to the full and more lengthy repair. You will need to get a crank puller for a tapered crank from a bicycle shop to complete the job. Talk to Schwinn support; they were really good the two times I called.
Here are a couple of pictures showing the storage bin removed and the correct position of the speed sensor.
Mar 08, 2014 | Schwinn 450 Elliptical Trainer
Need manual for schwinn personal trainer 405 tread mill
Hello Brend
Please download the assembly manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_430_AM_RevB_web.pdf
Please download the owners manual for Schwinn® 430 Elliptical from the link provided below :
Oct 10, 2011 | Schwinn 430 Elliptical Trainer
The computer on my schwin 418 eliptical does not work. Is there something I can do to fix it myself? Where can I get it serviced?
Call Schwinn customer service (actually Nautilus) at 1-800-nautilus if it is broken so you can order a new one or they will send you a new one if you are under warranty. They are very helpful. You can also check the power connection on the bottom or make sure the wire harness in the main pipe in the center is properly connected if the system is brand new and not working.
Jan 04, 2011 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
CardioStyle ET 150 Eliptical Trainer
It's at https://www.dixiesales.com/ipl/935/84-0101%20English%20Manual%20-%2009-24-07.pdf
Sep 24, 2009 | Exercise & Fitness
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
