Question about Motorola Mobility H350 Wireless Headset
Ring Tone Won't Stop
Someone has already posted this problem and I don't buy the "solution" provided.
The problem is that, after working correctly for weeks when answering a call (single tap, ring tone stops immediately, H350 is working full duplex as normal), NOW, when I single-tap to answer a call, the phone (V325i) picks up immediately but the headset continues to play the ring tone *even while the caller can hear me (i.e. the headset is ALREADY connected and communicating) but I can't hear anything in the headset until the ring tone FINALLY stops playing (4-6) seconds later! I have to say "Wait for my headset to stop ringing so I can hear you." at the beginning of every call now. Very irritating considering I use this thing for business.
THAT'S why I don't buy the "You just have to wait for the headset to connect..." solution.
FIRST, If the H350 wasn't connected, it would not be able to transmit my voice while I'm waiting for the ringing to stop. If you know anything about digital broadband data, you know this is automatically true.
SECOND, my headset was not behaving like this for the first three weeks I owned it. It worked as stated at the beginning of this note.
THIRD, the headset and phone begin the sync process the moment the call begins to ring. If there was any delay in connecting, I never encountered it while answering on my headset (usually before the second ring) until two days ago.
SO, question is: What changed? Is this a setting? A bug? etc...
Does anyone else have this problem? (At least one other person has experienced this).
Don't mean to shoot anyone down but the answer just doesn't satisfy me. Sorry.
    Problem Solver:
  • 4 Answers
Re: Ring Tone Won't Stop
Why on my headset will my boy friends phone play the music but on mine i just hear some duta du noise, my headset also will not stop ringing once the phone is answered?
Posted on Aug 31, 2008
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Posted on Jan 09, 2008
0 characters
3 Points
How to change the ring tone to my own ring tone for m165?
I agree. After checking with Plantronics - no "ringtone" is used. Simply call notification is used.- Sorry.
May 03, 2014 | Plantronics Headsets
Hi, one of our Call Center workers cannot hear the ringing phone when she has the headset onWhat's your problem?
The ring from the telephone is picked up by the internal microphone on the HL10 Handset Lifter, typically for most phones, the lifter sits directly over the speaker grill on the telephone where the sound comes out. For telephones that curve out on the left side and don't have a straight edge, there is an accessory called a "Ring Detector" which is used. Here's a link:
HL10 Nortel Adapter Kit - 46780-01
If the internal mic on the lifter has gone out, you can plug the ring detector into the handset lifter and just stick the ring detector over the speaker grill to pick up the ring. Plugging this into the lifter will bypass the internal mic, this accessory would have come with your HL10 lifter. You can also check the ring volume on the telephone, and you can also try adjusting the ring tone on the phone (sometimes it will pick up one ring tone better than another). Here is a link below if you need to order a new ring detector:
HL10 Nortel Adapter Kit 63014-01
Good luck from Headsets Direct!
Oct 27, 2011 | Plantronics PL-CS55 Wireless Headset
I want to send 1 ring tone through internet to my
just enter
and dawnload with your choice
Sep 10, 2009 | Sony Ericsson Bluetooth-Headset HBH-PV715...
H500 soft persistent beeping
this sound is the sound of count down from going from a standbye mode to shutting off itself to conserve battery thats all this is
cant stop it unfortunatly its built in feature
Jun 04, 2008 | Motorola Mobility H500 Wireless Headset
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
H700 Problem
I have a Motorola v557 and have to turn up the key volume in order to get the ring tone in my ear. Hope this helps
Dec 20, 2006 | Motorola Mobility H700 Wireless Headset
Why won't it ring?!
The same happened with my phone and it was a faulty soundcard. i took the fone back and they sent it off to find that it was a faulty soundcard and replaced it for me. Now the fone works fine.
Nov 15, 2006 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Motorola Mobility H350 Wireless Headset Logo
239 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
