Question about Brother HL-6050DN Laser Printer
5mm Gap in Print
All print is clear and sharp apart fro a 5mm vertical band where nothing prints. The band is 47mm from the left on an A4 sheet.Drum and toner have been changed
Soulvisitor
  • 1113 Answers
SOURCE: Replaced both toner and drum- prints too light
remove drom and toner, in base of machine is a glass slit, clean it.
Posted on Dec 16, 2007
SOURCE: HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Posted on May 12, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
  • 11 Answers
SOURCE: Lines on Paper
Under the drum there is a thin ****-glass. Make sure there is nothing on the glass. Do not use compressed air to remove the debris from the glass. Use a dust cloth or such. Using air will blow the debris into the laser unit and it will have to be taken apart to be cleaned.
Posted on Nov 02, 2008
SOURCE: Self cleaning and print test sheet
Click on the <Go> button 5 times fast for a test page. If it is not picking up paper, clean the rubber with Alcohol
Posted on Nov 18, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
White unprinted band on the top end of printed sheet
Look to make sure your developer is flowing evenly on the mag roller. Next I would check the scoretron\grid it is the saw tooth blade that faces the drum.
Aug 18, 2014 | Sharp AR-5320 Black and White Copier
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
3 dots along the left margin of paper, after replacing the drum
Open the MP tray and place a new sheet of A4 paper on it.
Press and Hold the Clear/Back button and also press and hold the Left Arrow. The display should change to 'Drum Cleaning'
Press the OK button and it should clean the drum and print a sheet with smudges where your dots used to be.
You may need to repeat the procedure a few times.
Apr 24, 2010 | Brother MFC-9440CN Laser Printer
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Dec 12, 2009 | Konica Minolta magicolor 2500 Printer
My Sharp 1642cs says replace drum cartridge on the lcd. Even installing a brand oem drum cartridge. It will not function at all. How do i reset it?
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 09, 2009 | Sharp AL-1642CS Copier
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
White bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Brother HL-6050DN Laser Printer Logo
14 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
