Reformating if i reformat my acer 7560-sb416 with out the erecovery recovery factory dicks. with just a new operating system using my windows disk will this work and do the job.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 74 Answers
If you are going to reformat your entire hard drive, you will need to use an OS boot/install disc from your optical drive, a windows XP setup disc is not enough to get the job done, you need Windows Vista/7 Setup DVD.
How To Format From Windows Setup Disc
The link will take you to a site that breaks out the process.
Posted on Feb 11, 2014
mtspace
  • 103 Answers
SOURCE: d2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Posted on Jan 04, 2008
xCAUSALITYx
  • 210 Answers
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Cheers
Posted on Jun 17, 2008
zohail
  • 1223 Answers
SOURCE: Acer eRecovery Wont Work
ok u can restore ur notebook to factory defaults without disk like this
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
pls rate me FIXYA !! or ask for more help
Posted on Apr 04, 2009
  • 130 Answers
SOURCE: In my Acer Aspire One, need eRecovery info..
yes, it will reformat and install everything you came with new, I own one and have had to recover it twice, but never use another manufacturers os disk on anything but the intended unit as it can cause conflicts or serious ir recoverable harm to the unit.
Posted on Jun 22, 2009
SOURCE: Acer recovery disk download
http://www.restoredisks.com/index.asp
Just ordered for my acer aspire 5315
Posted on Feb 09, 2010
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
How do i do a system recovery without a disk
Try This . When the System CD and Recovery CD are not available, you can create them by
using this feature.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery window, select Recovery settings and click Next.
5 In the Recovery settings window, select Burn image to disk and click Next.
6 In the Burn image to disk window, select 01. Factory default image and
click Next.
7 Follow the instructions on screen to complete the process.
Jun 24, 2011 | Acer Aspire 5500 5570-2609 Laptop
Why is my laptop is stuck in start up mode
Hi bungee221,
You can try to boot the system using Safe Mode and try to see it it will be able to boot so that you will be able to backup your file. In addition to that you disable other programs that might be causing the system not to boot up. Go to Safe Mode by reseting the computer then tapping F8. If your able to acces safe mode follow these instructions:
1. Go to Start then click on RUN.
2. Type MSCONFIG.
3. Go to Services Tab, click Hide Microsoft Services then click Disable All.
4. Reboot the computer and see it it will go to normal mode. It you will be able to boot to normal mode it only means that one of the installed software is preventing windows to load.
5. if still cant boot you neet to reformat the system. Take note that if you reformat the system all the files will be deleted so its better to back up the files first. You can use a Recovery Disk that came with the system or you do a Acer Disk Recovery.
Acer Dsik Recovery Steps:
1. Power on the Machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit.
If you think this helpful rate me and dont forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
Jul 15, 2010 | Acer Aspire 5050-3242 Notebook
Acer TravelMate 8200 recovery and system disks
Your hard drive has a hidden partition that contains the original factory OS and program stored for rescue and recovery.
1 Boot to Windows.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Dec 12, 2009 | Acer TravelMate 8200 Notebook
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
yes but it will reformat everiting dont forget to backupyour data
Jun 22, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
David Payne
David Payne
