Question about Midland 1001Z 40-Channels Base CB Radio
Pulse noise hooked up in house on lighter adapter. Weather works the cb side just makes a pulse sound
  • 1,162 Answers
Not sure what you mean. Can you give more info?
Posted on Mar 26, 2014
2 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: cb not working
Probably cold solder joints on the stand up if boards. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Which side is the cb and which side is the radio on a 2007 Columbia
make sure you have several 2a fuses with you then hook your red wire to the white wire in your truck then try to make the other one spark by flicking the two together. this is the poor mans way.the proper way way is to have a decent volt meter to check each wire then hook your wires up accordingly. the other is to buy a cigarette light plug and use that. the only dissadvantage is it may pick up a lot of engine noise.If you are not going to be the sole driver of this truck I would go with the cigarette lighter.If you are the owner operator than it would be best to have a cb shop install a plug in for you then you will have no worries, and thats what you want.
Mar 30, 2014 | Radio Communications
Midland 77-118 cb/ weather radio
sounds like the cb section is way off frequency. Check it out first.
Feb 11, 2014 | Midland Radio Communications
Midland 75 785 noise problem
change channels maybe it will go away. How is you power hooked up? does it go to the fuse box ,cigarette lighter or directly to the battery? Try hooking the power up differently .If that doesn't work try asking a friend to hook it up in their vehicle to see if it still does it. once you find the problem then install it. Could the nb/anl switch be in the off position ? Good luck.
Feb 07, 2013 | Midland 75-822 40-Channels Handheld CB...
How to hook a cb up to a 2000 isuzu rodeo
CB to vehicle--two choices--lighter plug with adapter but that way you will likely pick up noise from the electrical system.
Go directly to the battery, leads as short as possible and if possible get a noise filter in line right at the battery.
Apr 02, 2012 | Cobra 19 DX II 40-Channels Base CB Radio
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Cb radio doesn't give out any sound
You would be surprised how little people actually talk on CB radios these days. I went through similar struggles a few years ago. Unless you are in a major trucker area, the CB radio is basically silence.
Check out the weather channels (anything on the WX setting) to make sure that your radio is receiving frequencies correctly. If that doesn't work, then it is your box, but I bet that will work.
Oct 30, 2009 | Radio Communications
I can only get the weather channel but the cb side dosen't work what do you think it can be?
You don't give me much to work with. Is the weather selector switch in the CB position? Do you have an antenna hooked up? Have you checked the SWR on the antenna? What power reading do you get when you key the mike?
Please give me some feed back.
Jun 26, 2009 | Uniden PC68LTW 2-Way Radio
NO sound
Make sure the switch is in the CB position. If this is so, then you may have a bad switching transistor or a bad diode in the board. Also on some of the weather band cobras I have worked on in the past, I have found bad pll chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
