Question about Car Audio & Video
How to change the clock of eclipse AVN118M - Car Audio & Video
How can I fix my dashboard clock in my 2003 Mitsubishi Eclipse GS?
Press and HOLD the Minutes or Hours button and clock will set...
saailer
May 08, 2014 | 2001 Mitsubishi Eclipse
How do i change time on the eclipse cd5100
here is the link to your owners manual ans installation manual.
Eclipse Manual
here is the link to the eclipse site.
Eclipse Site
owners manual
setting clock is under
making changes with function mode
setting time
Mar 28, 2010 | Car Audio & Video
How can i find the fuse for my clock and stereo display?
had the same problem with my 03 eclipse. check your cigarette lighter fuse. powered on the same circuit. that was my issue
Mar 13, 2009 | 2003 Mitsubishi Eclipse Coupe
Eclipse CD8445 Clock Problems
If you lose your preset stations as well, it means that your memory wire (sometimes yellow sometimes red) is not hooked to a constant power source. Get a testlight and find a wire in where the radio is at that has constant power once you find that attach the memory wire.
Nov 17, 2008 | Eclipse 5440
Display mode is flashing
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
Nov 16, 2008 | 2002 Mitsubishi Eclipse
2002 Eclipse Spyder
The visor lite wiring is shorted this is a very common issue, replace it.
Nov 05, 2008 | 2000 Mitsubishi Eclipse
The CD/clock screen has stopped working...
Go to Best buy- have a new radio installed
Aug 15, 2008 | 2001 Mitsubishi Eclipse
Setting the clock on Eclipse cd5405 deck
Push the function button once. turn the right knob (SEL) untill CLOCK ADJ shows on the screen. push SEL in one time to lock in CLOCK ADJ and the hours will blink. Turn the SEL knob to set the hours. push SEL again to get to the min. Turn SEL again to set min.
Aug 29, 2007 | Eclipse CD5405
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
