Question about Porter Cable 9118 #126 Porta Plane Door Planer
Need color pencil numbers
Pencil by numbers
Where can i find the best Artist pencils set on the web now?
http://www.jerrysartarama.com/soho-professional-colored-pencils
Jul 09, 2016 | Audio Players & Recorders
How do I open the prismacolor pencil sharpener
Unlatch the clear Top Cover to lift up like a Toilet seat lid which is hinged by a SUPER FLIMSY strip of plastic to the opposite side of the unit. This done with the Sharpening Holes facing UP.
Sep 28, 2014 | Sanford Corporation Prismacolor Premier...
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
Crayon is stuck inside pencil sharpener
Hello, I need the model number of the pencil sharpner. You might go to bostitch and call support for help.
Jan 10, 2014 | Stanley Bostitch Electric Pencil Sharpener
What is so special about colored pencil sets?
What is so great about colored pencil sets is that they allow you to choose between many choices, shapes and sizes of pencil which can benefit you in more accurate and detailed paintings.
Feb 03, 2013 | Crafts & Hobbies
Hello, I recently bought some Mac eye/lip liner pencils, and am having trouble getting the color on my eyes.
Try applying your foundation before you apply your eye color. The powder will help the color set and make it last longer as well.
Mar 30, 2011 | M+ Mac Eye / Lip Liner Pencil Black Aloe...
Defrost
You will need to get this kit part number 4F1Z-14421-AA from your ford dealer.
  1. Place the replacement terminal over the original tab location making sure the conductive areas of the terminal will be on a good conductive area. Do not place the terminal tab foot on the original location which does not have conductive material (figure 4).
    Figure 4 - Article 04-24-5
  2. Hold the terminal in place with an item such as regular lead pencil at a 90 degree angle from the terminal. (Terminal type B can be held in place with tape.) (Holding at other than a 90 degree angle may allow the terminal to slip when the solder liquefies).
  3. Place the soldering gun tip on the top of the terminal but not on the painted areas of the tab. Energize the soldering gun and watch for the painted area of the terminal to liquefy and change color. The paint should liquefy in approximately 25-45 seconds after heating. As soon as the paint color completely changes on either side of the terminal, de-energize the soldering gun and continue to hold the terminal in place with the soldering gun and pencil for an additional thirty (30) seconds.
  4. Remove the soldering gun and pencil from the terminal. The terminal should be allowed to cool for another two (2) minutes before the wiring lead is attached to the terminal.
  5. Attach the electrical lead connection to this terminal, turn on the rear defroster, and verify operation.
Feb 27, 2009 | 1998 Ford Explorer
Lexmark 5400 series printer
Just today, our Lexmark 5400 began having paper jam issues. We'd try to print, and the paper would initially feed into the back and then wouldn't go any further. Then it gave printer jam error messages. After peering and poking into various areas of the unit I wound up disconnecting the printer from power, phone line, and USB connection, I took it to a better lit room.
Peering carefully into the back paper feed area, I discovered a pencil!! After excising the pencil, the printer worked fine. One of my precious children must have accidentally dropped a pencil into the back, or a pencil was resting on top of the unit and rolled into the back paper feed area.
Lesson learned, don't put pens or pencils on top of the printer.
Jul 09, 2007 | HP PSC 2210 All-In-One InkJet Printer
Porter Cable 9118 #126 Porta Plane Door Planer Logo
Top Porter Cable Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Porter Cable Craft and Hobby Expert? Answer questions, earn points and help others
