Question about Dell Computers & Internet
Dell s2309w aspect ratio menu is locked - Dell Computers & Internet
skotkolr
  • 558 Answers
SOURCE: aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Posted on May 08, 2008
landsend
  • 1066 Answers
SOURCE: TV has 16:10 Aspect Ratio - looks squeezed. Can I adjust?
there should either be a menu button on your TV or on your REMOTE after its pressed ...go to picture and there you can adjust the screen to your preferences.
Posted on Apr 06, 2009
SOURCE: 22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Posted on Apr 28, 2009
pravinbhavsa
  • 348 Answers
SOURCE: trying to use an acer H233H lcd monitor with a Dell 4600
you have to install the original video drivers into it .from www.drivers.com if you have original drivers then install an AGP card into an AGP slot then you can see higher resolution
Posted on Apr 08, 2010
budmrtn
  • 11361 Answers
SOURCE: Dell S2309W Monitor will not power on.
Sch will be really hard to come by since Dell does not really make the monitor, most of them are made by SAMSUNG and BenQ.
Send me pictures if you want, may be I can help you identify the bad parts. budmrtn@aol.com
That symptom may mean the power supply goes into shutdown mode due to short circuits.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 11, 2010
How do you adjust the aspect ratio or size of picture to fit screen? There is no aspect ratio setting that I can find in my menu options
In the newer TVs the aspect ratio is a separate setting 480 ,730 etc. Others you just go to settings,menu, picture, and select viewing preference. It can also depend on the source. some streaming devices, dvd, etc have aspect settings of their own.. check both.
Feb 08, 2018 | Televison & Video
I asked why the heads are cut off on my tv. I was told to adjust aspect ratio on the screen menu. I cannot find aspect ratio on screen menu. HELP
It will be listed as screen option, it will be "widescreen" "panoramic" and regular broadcast image, no such button as aspect but the above are aspect options.
Jan 11, 2017 | Televison & Video
How can I get rid of the nasty wide horizontal line on the screen of our TV manufactured 2008...? Will It be expensive to repair...?
If by "nasty wide horizontal lines" you mean LETTERBOX masks (at the top and bottom of the screen), all you need to do is select the correct ASPECT RATIO for the program you are watching. Consult your USER MANUAL to determine the menu settings for ASPECT RATIO.
If you do not understand what "aspect ratio" means, or what different aspect ratios exist, do an Internet search for "aspect ratio" and read.
May 21, 2015 | Televison & Video
Aspect ratio problem -- will not display 4:3
You should have an option in your menu for "ratio lock"... many older screens have a ratio lock setting that you can enable or disable. Hope that works!
Jan 15, 2014 | Televison & Video
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    Jul 11, 2010 | Dell S2309W Monitor
    Adjust resolution on lumix dmc-tz3
    Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
    Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
    Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
    You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
    Dec 30, 2009 | Televison & Video
    Occasionaly a wide screen dvd plays only in full screen
    The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
    Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
    Computers & Internet Logo
    20 people viewed this question
    Alun Cox
