Question about Kenmore Elite HE3 Steam 8674 Dryer
Can a high temperature thermostat be installed upside down?
It over heats knew water and thermostat oil looks good and coolant still over heats and some time we have heat we're bleeding it lost on what to do next
The thermostat may have been installed upside down. You need a minimum of 50% antifreeze and no more than 70% antifreeze to water to prevent overheating and freeze protection. The radiator may be plugged up due to age and corrosion. If it overheats while stuck in traffic, the fan motor or coolant temperature sensor could be defective.
Nov 08, 2015 | 2005 Pontiac Montana SV6
Changed thermostat water pump and radiator on my 2001 Buick Century but still keep running hot...what else could be the problem???HELP PLEASE
Check to see if the radiator fan is on when the AC is on. The new thermostat may have a higher operating temperature than the old one. The thermostat could have been installed upside down. The gauge is defective and reading the wrong temperature.
Sep 02, 2015 | Buick Cars & Trucks
Overheating
I hate to say it, but I think that you installed the thermostat upside-down. If so, the coolant is constantly circulating through the radiator, and it takes a very long time to come up to normal operating temperature, which means no heat to the passenger compartment. Try removing the "gooseneck" again and make sure that the "long" end of the thermostat is facing down into the engine. Good luck.
Oct 11, 2013 | 1996 Mercury Sable
How to change thermostat
the radiator is filled to the top with coolant and the engine is run without the radiator cap in place, the coolant will expand and spill over as the engine warms up.
  • Drain some coolant into a clean container until the coolant level is below the thermostat housing.
  • Remove the upper radiator hose connection from the thermostat housing.
  • Loosen the housing bolts and remove the housing.
  • Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
  • Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
  • The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
  • When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
  • Install the gasket.
  • Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
  • When the engine has reached operating temperature make sure the thermostat opens.
  • You should be able to see coolant circulating within the radiator.
  • Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
  • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stu
    CAUTION
    If the radiator is filled to the top with coolant and the engine is run without the radiator cap in place, the coolant will expand and spill over as the engine warms up.
    • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
    NOTE When a paper gasket is used and the recess is in the thermostat housing, it is a good practice to position the thermostat into the recess and glue the gasket to hold it in place. If it falls out of its groove during installation, the outlet housing can be cracked or a coolant leak will result. Before tightening the water outlet housing, try to rock it back and forth to be sure it is flush. Housings are often cracked during this step.ck closed and must be replaced.
May 07, 2012 | 1998 Mercury Mystique
Is the thermostat supposed to be installed upside down?
The sping side of the thermostat should always point towards the engine. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 07, 2012 | 1999 Ford Explorer
Why cant you install a upside down honeywell zone valve
from the manual. not to be unstalled upside down due to posible leakage.in other words if it leaks the water runs into the motor housing and the electrics, which will cause damage/danger
Oct 20, 2011 | Honeywell Programmable Thermostat Heater
Just had thermostat changed .......temperture gauge goes all the way up then slowly comes back to normal range..no heat in car
As I have written many times if your car is otherwise running fine, do not replace the thermostat and hope that it somehow fixes your heater core. In your case it actually sounds like you put a bad thermostat in and it is not opening at the correct temperature, but much higher. It could be possible that you put it in upside down and therefore the temperature on the outlet side has to be high enough to open it. On a car that new your core should still be good. I would pay a dealer to take a look at it there could be some common problem with the flap that lets the cool air being stuck in the full open position.
Dec 06, 2010 | 2004 Pontiac Grand Prix
How to install a 2005 chevy cobalt thermostat
Jan 14, 2010 | 2005 Chevrolet Cobalt
How do i replace thermostat in 2001 dodge dakota
Nov 21, 2008 | 2001 Dodge Dakota
How do I replace the thermostat in my 1990 buick LeSabre?
Hello thank you for using FixYa.com for your answer my name is David .
This should help you out if you have any other questions please let me know.
Nov 08, 2008 | 1990 Buick LeSabre
Kenmore Elite HE3 Steam 8674 Dryer Logo
22 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
