Question about Whirlpool GZ7730XGS Stainless Steel Kitchen Hood
Seems to be a power problem,is there a fuse in the hood
Fan and lights blew off
check the fuse. (see post about control board.)
excerpt: ... the control board is in the front of the hood behind the speed & light power buttons. There is a 3/4" Buss fuse onboard that seems to pop on my hood every few months.
Mar 06, 2014 | Zephyr Typhoon AK2100 Kitchen Hood
Cant fine the fuse for my windows and sunroof 2001 f150 supercrew 4door lariat
moonroof relay and 30 amp fuse should be under the hood in the power distribution box.owners manual also can help you locate all fuses and relays location.
Aug 31, 2012 | 2001 Ford F150 Styleside SuperCrew
Radio and navi won't turn on. Tried looking for blown fuse but unable to locate one. Help.
It helps to state what radio you have.....So did you find the fuse and its good?and getting power or just tried to find it? Try fuse 11 and 13 for the Nav. Fuse 8 and 9 inside and fuse 4 under hood for BOSE SYSTEM. Fuse 8, 9 under dash and 48 under hood for non BOSE
Dec 01, 2010 | 2003 Acura MDX
ZV950 Hood problem
transformer or fuse would not cause a problem. seems like cheap asian electronics are the problem. its a control panel issue
Aug 08, 2009 | GE ZV750SY Kitchen Hood
No power of any kind after tried to jump-start engine
No power at all check battery cabes and connection, check main power fuses with a meter. break may not be appearent. Think back you didnt by chance hook up cables backwards did you, important to know. all power goes through the main fuse block under the hood start there.
Nov 09, 2008 | 2004 Acura TL
My driver side power seats and side power mirrors don't work!
sounds like a bad fuse, have a look at your manual and see which fuse controls those parts, they are most likely on the same fuse, the fuse box may also say which fuse is for what, If the fuse in the first box doesn't fix it, try a new fuse in the box under the hood, let me know how this goes, you may also have corrosion in a wire but check the fuses first.
Jul 01, 2008 | 2003 Ford Windstar
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Whirlpool GZ7730XGS Stainless Steel Kitchen Hood Logo
66 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
