Question about Fujitsu fi-5120C
Calibrate fujitsu scanner - Fujitsu fi-5120C
What's the price of Fujitsu scanner model 5130?
As far as I can tell, a Fujitsu 5130 is a desktop computer, not a scanner. It sells for $2820 new.
A Fujitsu 6130 is a scanner, and sells for about $400 used.
May 16, 2015 | Fujitsu Office Equipment & Supplies
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Is there a firmware update for this scanner, the
Thank you for contacting Fixya.
Firmware update for your Fujitsu Fi-5750C scanner is available. However, this may not be available to download.Hence, you need to contact Fujitsu Technical Support for the same.
Hope the above information is helpful.
Regards,
TechSatya
Jan 27, 2010 | Fujitsu fi-5750C Flatbed Scanner
DOWNLOAD DRIVERS
Preferably download from Fujitsu here:
Driver Vista :9.18.709
Driver XP :9.18.149
If you still cannot download from website above (reccomended) , alternate download here: download driver for Fujitsu fi-4120C Scanner
Oct 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Calibrate
on your scanner program in your computer there should be calibration setting that will reset your scanner properly
Nov 26, 2007 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
21 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
