I can't find ANYONE to talk to , all I want is an address or some humin being and not machines
Does anyone have an email address where i can contact apple itself because apple support isn't helping me much! I need to talk to someone at apple America so they can reset my iPhone
Apple support ARE Apple. You will not be able to talk to anyone else, as they are a very structured company. If they are unable to help (and they are usually very good) then searching the apple forums usually answers most questions.
What do you mean by 'reset'? If you go to 'settings', 'General', 'Reset' on the phone, you can perform different sorts of reset (including deleting all data).
If you have forgotten your passcode then Apple cannot help you by phone. Go to https://support.apple.com/en-gb/HT204306 and follow the instructions. This will delete all your data, but allow you to reset the passcode.
Apr 05, 2016 | Apple Cell Phones
What does it mean when my Muratec Fax Machine says DHCP Server Did Not Respond and it will not send or receive documents?
DHCP is the way systems on a network get an address from the network. In a home environment, that's usually done by the router. Unless your fax machine is attempting to send faxes via the internet (rare), that isn't why your machine can't send or receive a fax. If you're talking about sending a fax from your computer, then not having an address is indeed the reason you can't send a fax from your computer.
You will need to see why your router isn't giving the fax machine an ip address. Is it connected to the router? Wireless? Wired?
Jul 08, 2015 | Muratec Office Equipment & Supplies
TRY GET CARZEL DUDE@HOTMAIL .COM
Talk to hotmail but any address that is not is use can be used by anyone.
Mar 09, 2014 | Dell Computers & Internet
Pattern Parts in Thailand
talk to anybody in china they will copy ANYTHING.........
Jul 11, 2010 | 2000 Volvo S80
Intermittent wireless Internet access
The problem started after you added the additional devices. Now you probably have all of your devices using DHCP which means the router provides an IP Address for your devices. Change the devices to have a fixed ip address. You may have to check the router for the default internal ip address, but it is probably 192.168.1.1 as the gateway. With the PC and laptop go to the control panel, then network connections, right clip on the connection and select properties, then scoll down the window until you see tcp/ip connection, select properties from the tab options below and set the ip address of each machine to 192.168.1.10, 192.168.1.11 and 192.168.1.12. set the gateway to 192.168.1.1 and set the dns ip to 192.168.1.1. Now if you have a different gateway address, use that as applied above. Save the settings and retry your connections.
Here is way you are probably having problems, wireless networks will drop and reconnect more often than a cable connection. If you were using just a cable connection, there would be less of a problem. When DHCP is being used and a computer drops the connection, it could get a totally different ip assignment the next time (a matter of less than a second of time). When that happens the original connection is lost. By fixing the ip address to be static, any time you reconnect via wireless, it uses exactly the same address, thus maintaining the connection.
Try it out and leave feedback if it works for you, otherwise send me the results of the test.
Feb 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
I want to find th A550 Handbook -can anyone help
If you're talking about the Sony DSLR A550 then the address to download a copy of the full 178 page manual to your computer is: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSLRA550
Jan 22, 2010 | Cameras
Load noise not spinning
hi if its a loud humin then its your berings. if its a banging then its your spider hope this helps
Jun 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Ameritech Cordless Phone Model 1933 with talking caller ID
I have the manual for the Ameritech phone Model 1933. I have scanned it and email it to you, if you provide an email address I can send it to.
I don't know how to attach it on this website (which is new to me).
Mar 27, 2009 | Alert Caller ID with Internet Answering...
Address book
Hi, are you talking about addresses for network scan?, if so load the scan disk on each users machine and save their profiles to the machine. regards
Andy
Jan 11, 2008 | Office Equipment & Supplies
Belkin router
What you are talking about would be data encryption.http://www.guardianedge.com/products/Encryption_Anywhere/index.html Once information gets past your router, its past your router. Your router is helping keep out any outside hackers. Your router is what is considered a "hardware firewall" It takes your outside IP address and changes then multiplies the address to make as many connections(up to 255) per router. If your router is set to DHCP your address changes every 2 days or so. Your cable modems' address also changes every few days. That makes it hard for anyone to hack into your machine. Tim
Feb 14, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
