Question about Fuji Office Equipment & Supplies
300 g paper
Paper ribbon jam on ask 300
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Posted on Aug 29, 2009
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
Paper jammed and cannot get out - how?
1)Don't try to remove the paper by pulling hard when its stuck.
2)As soon as paper gets jammed switch off your printer immediately.
3)I recommend switching it off by the button on the printer and not the external power switch.
4)Then wait 20 seconds and switch it on, your paper will come out unless its very tightly jammed and absolutely crammed
5) If it doesnt come you have to take out the the printing ribbon. There would be a handle on the upper portion of the place where you supply the papers. Take it out slowly. Make sure that the power is turned off while you do this.
6) Once you take the ribbon out the paper will be no longer jammed and you will be able to remove it manually.
7)After removing the jammed papers replace the ribbon and reset the printer(Resetting procedure varies according to model but usually its done switching the power switch(present on the printer) on while pressing the test print button(the external power switch should be on and current should flow).
Jun 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Aug 29, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper jam
Ohh Paper jam, so you open the printer front cover or Tonner catridge or ribbon catridge. then smothly remove the paper. its depend upon the printer.
Thanks
Aug 15, 2009 | Office Equipment & Supplies
Samsung CLP 300 printer jams when using legal size paper. I've changed the paper size in the properties menu and it still jams every time. Help.
Make sure the paper setting in the printer driver software is set correctly. Sometimes that can cause this problem.
Aug 04, 2009 | Samsung CLP 300 Laser Printer
Canon MX300 printer shows jam and no paper in
I got hold of Canon support & he had me give him a # behind the white ribbon inside & after that he asked when purchased (7-28-08) Now I will be getting a new unit and have to send back old one at NO cost to me. Who knows???? Was happy with the outcome & surprised!
Nov 16, 2008 | Canon PIXMA MX300 All-in-One Printer
Ribbon jamming in printer
i will simply advice you to pick another printer instead of the mother board because it might not be the only problem your printer has
Mar 06, 2008 | Olympus Camedia P-10 Thermal Photo Printer
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
13 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
