Set time i capture dock clock - Audio Players & Recorders
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
How do I set the time on my logitech iPod dock?
1. Press the power button on the dock. Press the Select button until the large clock is displayed on the lcd screen. 2. Push and hold the select button until you see the clock time display. 3. Set the time using the arrow buttons.
Mar 05, 2011 | Computers & Internet
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
Setting clock or get copy of manual/instructions for the entire clock/ipod dock.
Setting the clock:
1. Press the set button 3 times until all of hte digits for the main clock are flashing.
2. Press the Skip Forward and Back button for the hour and the Volume Up and down for the minutes.
3. Press Set button once to confirm and exit the setting menul.
Call 866-387-2027 for manual
Oct 14, 2009 | Starlite Next Play Clock Radio with iPod...
Lost the manual for my nexplay alarm clock/ipod dock
Setting the Clock:
1. Press the SET Button 3 times until all digits for the main clock are flashing.
2. Press Skip forward and back to change the hour and Volume up and down to change the minutes.
3. Press the set button once to save.
Sep 11, 2009 | Starlite Next Play Clock Radio with iPod...
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
22 people viewed this question
 Grubhead
Grubhead
