Question about Tablets & eReaders
Cannot connect to camera - Tablets & eReaders
Why wont the camera work, says can't connect to camera
if the camera needs a driver to communicate with the camera has one been installed. If you want to transfer data best way is cable
Jul 18, 2015 | Tablets & eReaders
How connecter a camera
this tablet has a usb port. Try using that port to connect a usb camera. You realize that this tablet already has two built in cameras, or are you talking about a camcorder or some other type of camera you want to be able to connect?
Mar 08, 2015 | Hipstreet Aurora 7 inch Tablet with 8GB...
Camera error, can't connect to camera
Happened to me today with a Nexus 5; I rebooted the phone, the error went away.
Sep 25, 2014 | Tablets & eReaders
Why does my tablet say "cannot connect to camera"?
You should be able to go to the website of the camera for a software patch.
Jul 02, 2014 | Archos Arnova 7 G3 Tablet
How do I take photos from digital camera and put them on samsung galaxy tablet?
Several ways:
email to yourself and open it on the tablet
connect both your camera & tablet and transfer the files...
take out the SD card from your camera and transfer to your PC and then connect your tablet and copy to the tablet.
May 29, 2014 | Samsung Galaxy Tab Tablet PC
I have a hannspree SN1AT71WEE301 i cannot connect to the camera is there an easy fix.
Assuming the built in cameras are the issue,
\are you using the provided software ?
You can try to update the ROM and / or drivers for those devices.
sometimes an update may not install properly and re-updating the ROM and / or specific device drivers would solve the issue
Attached is a link for the English device manual:
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN1AT71/SN1AT71_User-s_Manual_EN.pdf
If you are having difficulties with the device recognizing an attached camera device, you may need to go to camera device manufacturer website and download the appropriate drivers to match your tablet device operating system and connection type.
Ex: USB driver for camera connecting using a usb port connection. Also ... confirm proper cable is being used.
Ex: Some connections require 5 contact point cables, others only 4 contacts - this will be determined by your devices.
I hope this was helpful.
May 08, 2014 | Hannspree SN10T1 101 Tablet
CANNOT CONNECT TO CAMERA
sounds like the camera it's self has quit IE hardware problem, this is not uncommon, still under warranty.
Mar 21, 2014 | Tablets & eReaders
The camera stopped working. and every time I go on the camera it says camera error ,couldn't connect to the camera
Hi, try going into settings > Applications > (scroll right to all) > Camera > Clear Data. This won't delete any of your photos but rather your camera settings.
Mar 18, 2014 | Kurio 7S 7" 8 GB Black Tablet Android 4.2,...
Camera don't want to connect to android tablet
A couple things to check. Sometimes the router will not allow you to use an Outside IP address to view your cameras if you are Inside the same network as the DVR. I know AT&T for sure does not allow you to go from inside your network, to an outside IP address that directs you back to your inside network. Sorry is this sounds confusing. To test this, turn WiFi off on your Android and try to access the cameras. If you cannot connect inside or outside your network, then you should try to verify you can connect with a computer. Use a PC or laptop to see if your cameras are visible. If you can access the cameras on PC, make sure there is not another port that needs to be opened for the mobile devices. Geovision DVRs for instance require some changes in the DVR itself to allow mobile devices to connect. Email me back with your DVR model and what carrier you have, the phone model and the internet provider. But you must first try getting to view your cameras on a PC to see if the setup was the issue. Good luck.
Oct 24, 2013 | Amazon Kindle Fire HD
Why can't connect to camera,it's working but now its showing message cannot connect to camera.i just purchased it 2 weeks ago
In my case was just an app. "Lantern" - flashlight using LED...after uninstal that "s*tty" app the camera was OK again.
Aug 24, 2013 | Nextbook Premium 7 Capacitive Touch...
Tablets & eReaders Logo
10 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
