Question about Home Security
Artslon bell push
I have Aerslon non wore system with three chimes in situ, they will not operste now vis the bell push.
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Posted on Apr 22, 2010
  • 4736 Answers
SOURCE: I have a desa
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
  • 1212 Answers
SOURCE: Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Posted on Dec 31, 2011
  • 188 Answers
SOURCE: will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Posted on Jul 17, 2012
BAMOUT
  • 2478 Answers
SOURCE: Wireless door bell push is broken
Try Goggle it, Artslon bells
Posted on Mar 08, 2014
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
How do I set the chimes
Chimes are usually set from inside the bell-push, so that you can have multiple bell pushes and different chimes for each one.
Feb 13, 2015 | Home Security
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
Will my wireless bell push work with another manufacturers door chimes?
Jul 17, 2012 | Home Security
I have just purchased a wireless doorbell but it does not explain how to change the tune, please help.
Most wireless Door bells go ding-dong! Does your doorbell play Greensleves, or Home on the Range?
Did you get 2 buttons with it?
One is for the front, which makes the bell chime one way and the other is for the rear and it makes it chime differently.
Jun 29, 2011 | Vacuums
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Mar 09, 2011 | Desa International White Wireless Plug In...
Warning bell won't stop sounding
Section 13-09: Gauges, Warning Devices — Chime System 1996 Windstar Workshop Manual
DESCRIPTION AND OPERATION Warning Chime Systems Three distinct sounds are used to indicate the area of concern. Seat belt warning generates 1 chime per second
key-in-ignition generates 2 chimes per second
headlight on generates 4 chimes per second.
Key-In-Ignition Warning The key-in-ignition warning will sound when the driver's front door (20125) is opened with the key in the ignition switch. It will continue to sound until the key is removed, the front door is closed, the ignition switch is turned to START or the vehicle speed is over 24 kmh (15 mph).
Safety Belt Warning When the ignition switch is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
  • The safety belt warning indicator lamp (10C859) will activate for 60 seconds or until the driver's safety belt is fastened. Both the chime and lamp activate at the same time.
Anytime the ignition switch is released from START and returns to RUN while the safety belt lamp or chime is activated, the safety belt warning lamp or chime will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Headlamp Switch On Warning The chime will be activated if the headlamps or parking lamps are ON, the key is not in the ignition and the driver's door is opened. The chime will sound at a rate of four per second.
Apr 23, 2009 | 1996 Ford Windstar
Jan 19, 2009 | Desa International White Wireless Plug In...
Home Security Logo
12 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
