Question about Epson PictureMate Office Equipment & Supplies
How to clean epson head does not print every line.
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
SOURCE: my epson r290 produce streaking lines during photo printing
set the setting it to best photo
Posted on Mar 22, 2009
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
SOURCE: Describe your Epson Photo 1400 Stylus
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
Posted on Jul 20, 2010
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson r220 prints black lines through photos ect anything I print
The problem caused by waste ink at bottom plate arround head sprayer. Clean it. Turn off printer. Move head to center. Put wet tissue (with warm/hot water) upper head cleaning pad. Move head to right (parking position). wait for 10 minutes. Repeat it for 2-3 times. Check nozzle.
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Lines on prints
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
