Question about LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive
Charge for HD LC3U2 - LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
How long should a kindle fire hd be charged
If you use the charger that came with your kindle fire, you can rest knowing that it will not overcharge by leaving it plugged in too long. Usually 4 to 6 hours should fully charge it though.
Feb 20, 2015 | Amazon Kindle Fire HD
My kindle will not charge?
The Kindle Fire HD, if completely discharged, may take several hours to begin to accept a charge again. Simply leave it plugged in long enough and the on-board system will sort it out.
Feb 01, 2015 | Amazon Kindle Fire HD
My kindle 7HD worked for a couple of weeks, but now it won&#39;t charge or turn on. what do I do?
You probably broke the USB connector that is used to charge your kindle.
You could take it to a repair shop and see if it can be replaced.
Jan 20, 2015 | Amazon Kindle Fire HD
Why does this unit not take a full charge and indicates low battery and shuts down when you attemot to record in hd ?
The battery in it is going bad, or not charging due to oxidized contacts or faulty wiring. When it goes into HD mode, it requires a full voltage, and at least one cell may not be holding charge. You'll have to replace the battery, most likely, unless the charger or charger wire is bad.
Jun 16, 2010 | Coby CAM5001BLK 2" TFT LCD Snapp HD...
I have had the samsung hd icon(i8910) for a week and think its great. Problem is when i tried to delete an sms i was typing the screen locked up. No biggy. But the battery went flat and i had to charge it...
its also happened 2 me when i started using the secrete keypad code of samsung omnia hd i8910!!!! then the battery icon of my omnia hd is not moving anymore!!!! WHY??? HELP ME GUYS!!!! PLEASE!!!
May 20, 2010 | Samsung OmniaHD i8910 Smartphone
LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive Logo
51 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
