Question about HP Compaq nc6220 Notebook
Dual monitor problem
I am trying to use an additional monitor to show a different screen to that of my laptop so that I can use PowerShow for PowerPoint - Laptop to show slide sorter and other monitor to show Slideshow. But whatever I try it does not seem to recognise the PnP monitor as an additional screen but just as a duplicate of what is on my laptop
What do I have to do to configure my laptop properly?
  • jerict Oct 27, 2007
    Many thanks - seems to have done the trick
  • Rachna Gogna
    Rachna Gogna Jun 14, 2008
    hi my name is rachna gogna. i am trying to create new presentation to powerpoint, but i am not able to do. because my powerpoint doesnot have any slides, designs, graphs,etc.. so please help me with this as soon as possible.
  • 363 Answers
Change the monitor properties from clone to dualview
Posted on Oct 27, 2007
  • Martin B
    Martin B Oct 27, 2007
    In the display properties I mean.
  • Martin B
    I'm glad that worked, remember to rate me.
    Cheers
I have a problem with displaying power point presentation
Hello, Chris.
I'm not certain if this was already tried, but here goes:
If you look at you keyboard function (F) keys, you'll see a symbol or the words "CRT/LCD". On my laptop, it is F8, but could be different on yours.
When you connect an external screen to your laptop, if the laptop information doesn't show on the external screen, press your Fn key plus that function key with the symbol or words.
Normally, when you press once, twice and three times, you toggle through various options: your laptop screen only, your external screen only and both screens.
Hope this helps.
Nov 10, 2009 | Acer Aspire One PC Notebook
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
Connecting a Compaq nx6310 laptop to a bigger monitor
Should be Function Key and F4 (or a similar FKEY will show a monitor screen)
Press 1x to push image to ext. monitor
Press 2x to have dual display
Push 3x to just have laptop screen
Dec 08, 2008 | HP Compaq WF1907 Monitor
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
May 12, 2008 | IBM ThinkPad T43 Notebook
Using the TV as a computer monitor
I am assuming that you have installed the cable to the appropriate jack/connectors on the back of the TV and that of the PC.
If you are using a laptop, you would need to press on the Fn + F? keys of the laptop to cycle through the different settings such as: laptop's display only, laptop & TV displays and TV display only. The F? key would be one in your laptop designated to engaged/enable external monitor (TV). Normally, it would have a monitor icon.
Please verify that your PC's screen resolution is 1366 x 768 or lower.
If you are using a desktop, you need to engage/enable the dual/twin view in Display Properties. Additionally, the TV must be powered on first before the desktop is booted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 30, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
HP Compaq nc6220 Notebook Logo
337 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
